[GRASS-dev] G.proj requirements?
tlaronde at polynum.com
Sun Dec 17 08:08:15 EST 2006
Hello Paul,
On Sun, Dec 17, 2006 at 07:42:16AM +0000, Paul Kelly wrote:
> This would need quite a bit of re-engineering to fix in an elegant way,
> definitely worth thinking about though IMHO. For now, looks like a
> complicated workaround is required. :(
FWIW, and if I understand correctly the problem, now when I set a new
system, a template LOCATION is created to avoid the chicken and egg
problem. This serves multiple purposes:
1) This is a simple example that can be used for a quick demo/teaching (this
is not Spearfish);
2) This holds informations to verify that the current layout of the data
matches the library (organization of the GISDATABASE in KerGIS may vary
from version to version);
3) There is always a LOCATION/MAPSET to create other ones.
Actually, in PostgreSQL for example, you always derive a new database
from a template[12] one.
This ensures integrity and symetry of the commands (no need to handle
the special case of ab ovo).
HTH
Thierry Laronde (Alceste) <tlaronde +AT+ polynum +dot+ com>
http://www.kergis.com/
Key fingerprint = 0FF7 E906 FBAF FE95 FD89 250D 52B1 AE95 6006 F40C
