[GRASS-dev] G.proj requirements?
Sun Dec 17 11:48:37 EST 2006
Michael Barton wrote:
> Should I wait a bit then to see if this can be resolved in g.proj and not
> implment a TclTk workaround yet?
If you're talking about creating a dummy location/mapset, I'd rather
see one function in libgis to do this than having essentially the same
code duplicated across various modules and scripts.
