[GRASS-dev] Patch for QGIS ticket 448 (cannot start database driver)
Radim Blazek radim.blazek at gmail.com
Sun Dec 17 11:53:25 EST 2006
Here is the patch for https://svn.qgis.org/trac/ticket/448
(grass/lib/db/dbmi_client/start.c).
Unfortunately if QGIS is compiled without stdin/stdout and then run
from batch, cmd.exe or MSYS shell, it will open command window for a
while always when a new GRASS database driver is started.
Radim
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20061217/d131a1f8/start.c.obj
