[GRASS-dev] no X monitors
Mon Dec 18 09:51:10 EST 2006
Paul Van Deusen wrote:
> I compiled grass62 on two computers using this sequence of commands:
> 1) ./configure --without-opengl
> 2) make
> 3) make install
> On the computer that was upgraded from Fedora Core 5 to FC6 its fine,
> On the FC5 computer I have no X monitors, eg d.mon -l gives:
> GRASS 6.2.0 (usgrid):~ > d.mon -l
> name            description
> PNG             Create PNG Map
> png1            Create PNG Map
> png2            Create PNG Map
> png3            Create PNG Map
> png4            Create PNG Map
> png5            Create PNG Map
> png6            Create PNG Map
> png7            Create PNG Map
> gism            Create PNG Map for gis.m
> How can I get X0, X1, etc.  Does this have something to do with FC5.
This probably means that XDRIVER failed to compile. Check the
error.log file to see if that is the case; if so; examine the output
from "make -C display/drivers/XDRIVER" for clues.
