[GRASS-dev] Re: winGRASS
Michael Barton
michael.barton at asu.edu
Mon Dec 18 13:53:43 EST 2006
OK. Thanks. I'll put up a version to test momentarily.
Michael
On 12/18/06 11:50 AM, "Glynn Clements" <glynn at gclements.plus.com> wrote:
> Michael Barton wrote:
>>> 9.3 MS Windows
>>> The name of the Ghostscript command line executable on MS Windows is
>>> gswin32c so use this instead of the plain 'gs' in the quickstart
>>> examples.
>>> You must add gs\bin and gs\lib to the PATH, where gs is the top-level
>>> Ghostscript directory.
>>> When passing options to ghostcript through a batch file wrapper such
>>> as ps2pdf.bat you need to substitute '#' for '=' as the separator
>>> between options and their arguments. For example:
>>> ps2pdf -sPAPERSIZE#a4 file.ps file.pdf
>> Will this work for all versions (*nix as well as Win)? If so, I can just
>> change it universally and not worry about whether it is on a windows systems
>> or not.
> It seems to; e.g. "gs -sDEVICE#nullpage" works for me on Linux.
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
