[GRASS-dev] running with GISBASE as a symlink?
Hamish
hamish_nospam at yahoo.com
Mon Dec 18 23:23:14 EST 2006
William Kyngesburye wrote:
> A couple notes on the problem.
> Hamish wrote:
> > I am trying to work around this QGIS GRASS-plugin bug:
> > https://svn.qgis.org/trac/ticket/346
> > (the OSX file picker won't let me select GISBASE which is within a
> > subdirectory of /Apps/GRASS.app/; it's greyed out)
> Indeed, on OSX you can't navigate into an application package. And,
> depending on Finder options, you may or may not see the .app
> extension.
> If it's a valid GRASS installation and was built against that
> particular GRASS, it should work - a unix path can refer to something
> inside an app package with no problem. As long as that GRASS is not
> moved, Qgis GRASS plugin should find it and not ask for a GISBASE.
> Once GRASS is moved, Qgis needs to ask where it now is.
If I start QGIS from the GRASS command line (your 6.2.1 package), then
$GISBASE is already set and the GRASS plugin works, but $GISBASE is not
stored.
If I start QGIS from outside GRASS it asks for GISBASE, but then I run
into the GRASS.app/ selection problem.
Indeed setting $GISBASE as an enviro var before launching QGIS from a
(non-GRASS) Terminal gets it to work.
Also to note WRT hardcoding paths: The first thing I did after
installing your GRASS.app was to rename it GRASS_6.2.1.app. Too many
machines in the student computer lab to keep track of details otherwise.
Also have that in a /Apps/Grass/ folder, as I store PDF instructions
manuals there too.
> One solution I can think of, and that I'll probably do with my Qgis
> binary in the future, is to package the necessary GRASS libraries and
> support in the Qgis app. That way there are no worries of moving
> GRASS around and having to set GISBASE, or making sure you have the
> right GRASS version. It works for me with my GDAL framework -
> currently my Qgis build uses the GRASS libraries I have in my GDAL
> framework.
> I wonder - are you using the Qgis.org download of Qgis and trying to
> use my GRASS.app with it? This email implies that, though your Qgis
> bug says Lorenzo's. There *may* be library version incompatibilities.
I am now working with the 0.8pre2 binary from qgis.org + your 6.2.1
package + your 17 Dec frameworks package.
Earlier I was working with Lorenzo's 6.2.0beta2 package + grasslibs.
These are now outdated & removed.
> As for hacking the path, ~/Library/Preferences/org.qgis.qgis.plist.
> Don't know the setting name to use, though. Maybe GRASS.GISBASE?
Yes, on the mac it seems to be ~/Library/Preferences/org.qgis.qgis.plist
But it is a binary file I don't know how to modify/browse that?
On linux it is stored in ~/.qt/qgisrc as a simple text file:
[grass]
gisbase=...
so "GRASS.GISBASE" is a good guess.
> Or you could try using the GRASS libraries inside my GDAL framework -
> you can navigate into a framework package. Or try my Qgis build ^_^
In the future perhaps, but for now I would like to help fix this problem
at the root.
> William Kyngesburye <kyngchaos at kyngchaos.com>
> http://www.kyngchaos.com/
> All generalizations are dangerous, even this one.
cheers,
Hamish
