[GRASS-dev] [bug #5398] (grass) Problem with paths to wish84 etc
Request Tracker grass-bugs at intevation.de
Wed Dec 20 10:25:32 EST 2006
this bug's URL: http://intevation.de/rt/webrt?serial_num=5398
Subject: Problem with paths to wish84 etc
Platform: WindowsNT/2000/XP
grass binary for platform: Compiled from Sources
GRASS Version: windows native Grass
When installing the native windows binary GRASS version, under xp professional, the path to wish84 is a problem.
Grass.bat currently holds:
set GRass_WISH=wish84
which causes an error at startup
set PATH=%PATH%;C:\Program Files\PostgreSQL\8.1\bin;
set PATH=%PATH%;C:\mingw\bin;
set GRASS=grass
set GRASS_WISH=wish84.exe
fixes the problem.
This behaviour was first reported & the workaround defined by Dr. Kai Sonder, Nigeria.
-------------------------------------------- Managed by Request Tracker
