[GRASS-dev] ps.map fprintf -> G_
Martin Landa
landa.martin at gmail.com
Tue Dec 26 05:16:44 EST 2006
Hi all,
trying to change fprintf to G_message/warning/fatal_error in ps.map
module I found one complication. There is a special mapping
instruction --- VERBOSE. I think this instruction should overwrite
GRASS_VERBOSE environment variable(??). There is also need to have a
special function G_set_verbose() which allows to set a given verbosity
level after first calling of G_verbose() fn. Please look at the patch
(especially at verbose.c.diff). Thanks a lot.
Best regards, Martin
Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
Type: application/x-gzip
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20061226/84d80004/ps_map_vq.diff.gz
