[GRASS-dev] Re: GIS Manager and Map Display 1 faults on Ubuntu 6.06
Andreas Gros
andreas.gros at biozentrum.uni-wuerzburg.de
Thu Dec 28 04:57:26 EST 2006
Hello Stefan,
had the same problem with Ubuntu 6.06. Now that I installed 6.10 this problem
is gone. Haven't figured out what exactly the original problem was, though.
Kind regards,
Andreas
> I did not care about the kernel - he is running with a realtime-patch.
> Maybe this is causing the failures - but I do not understand how this can
> affect grass? Are there known problems when grass (gui-) functions are
> heavily interrupted?
I guess I don't know the answer to this. Maybe someone else does.
> Sometimes, I run a VMWARE server with both W98 and W2k on this box too. But
> they are run pretty smooth; so for me the base system is stable.
Does g.region work OK? If not, it will affect a number of features in the
display controls of the GIS Manager.
Michael
> Mit freundlichen Grüßen / With kindest regards
> Stefan Paulick
> http://www.urbeli.com
> mailto://stefan.paulick@urbeli.com
Andreas Gros (PhD-Student)
Fieldstation Fabrikschleichach
University Wuerzburg
Glashuettenstr. 5
96181 Rauhenebrach
Tel.: +49 931 888 3079
Fax.: +49 931 888 3089
