[GRASS5] Platform for next generation UI
Glynn Clements
glynn at gclements.plus.com
Mon Jan 2 08:36:59 EST 2006
William Kyngesburye wrote:
> There is also the question of 'platform distictiveness' vs. 'cross-
> platform blandness', as someone put it on the Qgis dev list (in
> response to a Mac question I had), in toolkits.
> It appears that Qt is moving towards the blandness end in Qt 4 - that
> is, doing specialized things the same on all platforms, instead of
> using platform widgets where possible. This may make an application
> easier to develop across platforms, and make it more consistent and
> stable across platforms, but you may make it more difficult to use
> the application as well, if it doesn't behave like an application
> should on your chosen platform.
> A specific example that I asked about with Qt on Mac OS X for Qgis:
> - Open/Save dialogs are pure Windows design. At least when they are
> customized. Without any customization (filters, extra popups or
> buttons), Qt uses a Mac open/save dialog. Add customization and Qt
> uses it's own, which is a Windows design. This can be very confusing
> for a Mac user if they aren't familiar with other platforms. Even if
> they are, the context of having this strange dialog box in a Mac
> environment could be confusing.
> I'm not sure how Tcl/Tk Aqua deals with this - plain open/save
> dialogs look fine, but I couldn't find any customized open/save
> dialogs in GRASS to see that case. Of course, Tcl/Tk in Apple X11
> works like any other X-based Tcl/Tk.
> And since the Mac GTK port is only just starting, who knows how it
> will behave...
> I would definitely prefer platform distinctiveness in a GUI.
Whilst native look-and-feel is desirable, it isn't the only factor to
be considered when choosing a toolkit. It may also involve more work,
as some of the differences can't easily be hidden within the toolkit.
