[GRASS5] Makefile problem - Re: [GRASS-announce] GRASS 6.0.2RC3 released
Markus Neteler
neteler at itc.it
Tue Jan 3 08:45:48 EST 2006
> * bugfix for 'builddemolocation target' in Makefile
> when building as root (RPMs etc)
Unfortunately I still have the following problem:
[root at bild-mandriva2006 dist.i686-pc-linux-gnu]# ls -l dist.i686-pc-linux-gnu/
insgesamt 40
drwxr-sr-x 3 1338 204 4096 Jan 3 14:21 demolocation/
drwxr-xr-x 3 root root 4096 Jan 3 14:22 docs/
drwxr-xr-x 4 root root 4096 Jan 3 14:22 bwidget/
drwxr-xr-x 2 root root 4096 Jan 3 14:22 fonts/
Although 'tar' is used in the 'builddemolocation' target in the
main Makefile, the owner is still preserved (1338 above).
It must be the owner compiling GRASS (here, root), otherwise the
virtual session to generate the HTML manuals fails.
Any ideas?
Should
id -un
be used to make a chown of demolocation/ after copying it?
Markus
