[GRASS5] GRASS 6.0.2RC3 released
Māris Nartišs
maris.gis at gmail.com
Fri Jan 6 04:20:14 EST 2006
gigi lol!
Huh, hi!
somebody created "cool" 6.0.2RC3 version - precompiled source ;)
Download rc3 from grass.itc.it, untar, ls
raster/r.le/r.le.setup/polytocell will give not only *.c but also *.o
:) This version is compiled for AMD64.
Solution: before make run make clean.
Nice day 2 all.
Maris.
2006/1/6, Scott Mitchell <smitch at mac.com>:
> Strange, in trying out 6.0.2RC3, I'm getting a compilation error on
> all machines that I haven't seen mention of:
> [smitch at gracilis r.le.setup]$ make
> Makefile:16: warning: overriding commands for target `clean'
> ../../../include/Make/Rules.make:35: warning: ignoring old commands
> for target `
> clean'
> echo "<HR>" >> r.le.setup.tmp.html
> echo "<P><a href=index.html>Help Index</a>" >> r.le.setup.tmp.html
> echo "</body></html>" >> r.le.setup.tmp.html
> mkdir -p /home/smitch/src/grass-6.0.2RC3/dist.i686-pc-linux-gnu/docs/
> html
> mv -f r.le.setup.tmp.html /home/smitch/src/grass-6.0.2RC3/dist.i686-
> pc-linux-gnu
> /docs/html/r.le.setup.html
> /usr/bin/install -c *.png *.jpg /home/smitch/src/grass-6.0.2RC3/
> dist.i686-pc-li
> nux-gnu/docs/html 2> /dev/null ; true
> make -C polytocell
> make[1]: Entering directory `/home/smitch/src/grass-6.0.2RC3/raster/
> r.le/r.le.se
> tup/polytocell'
> gcc -Wl,--export-dynamic -L/home/smitch/src/grass-6.0.2RC3/dist.i686-
> pc-linux-gn
> u/lib -o /home/smitch/src/grass-6.0.2RC3/dist.i686-pc-linux-gnu/bin/
> bmif_to_ce
> ll bmf_to_cll.o -lgrass_gis -lgrass_datetime -lz -lm -lz
> bmf_to_cll.o: file not recognized: File format not recognized
> collect2: ld returned 1 exit status
> make[1]: *** [/home/smitch/src/grass-6.0.2RC3/dist.i686-pc-linux-gnu/
> bin/bmif_to
> _cell] Error 1
> make[1]: Leaving directory `/home/smitch/src/grass-6.0.2RC3/raster/
> r.le/r.le.set
> up/polytocell'
> make: *** [default] Error 2
> [smitch at gracilis r.le.setup]$ gcc --version
> gcc (GCC) 3.3.3 20040412 (Red Hat Linux 3.3.3-7)
> The above is on a Fedora Core 2 machine - I got the same error on a
> FC4 machine. Also a similar error on a Mac (OS X 10.4, gcc 4):
> [smitch at stipa:~/src/grass-6.0.2RC3/raster/r.le/r.le.setup]$ make
> for target `clean'
> mkdir -p /Users/smitch/src/grass-6.0.2RC3/dist.powerpc-apple-
> darwin8.3.0/docs/html
> mv -f r.le.setup.tmp.html /Users/smitch/src/grass-6.0.2RC3/
> dist.powerpc-apple-darwin8.3.0/docs/html/r.le.setup.html
> /usr/bin/install -c *.png *.jpg /Users/smitch/src/grass-6.0.2RC3/
> dist.powerpc-apple-darwin8.3.0/docs/html 2> /dev/null ; true
> make -C polytocell
> gcc -L/usr/X11R6/lib -L/sw/lib -L/Users/smitch/src/grass-6.0.2RC3/
> dist.powerpc-apple-darwin8.3.0/lib -o /Users/smitch/src/
> grass-6.0.2RC3/dist.powerpc-apple-darwin8.3.0/bin/bmif_to_cell
> bmf_to_cll.o -lgrass_gis -lgrass_datetime -lz -lz
> /usr/bin/ld: bmf_to_cll.o bad magic number (not a Mach-O file)
> make[1]: *** [/Users/smitch/src/grass-6.0.2RC3/dist.powerpc-apple-
> darwin8.3.0/bin/bmif_to_cell] Error 1
> All other modules compiled cleanly.
> Cheers,
> Scott Mitchell
> > Two important fixes made it necessary to create a new
> > package.
> > GRASS 6.0.2RC3 was released today:
> > http://grass.itc.it/grass60/source/
> > 12043 Jan 3 14:12 AUTHORS
> > 134279 Jan 3 14:12 ChangeLog_6.0.2RC3.gz
> > 56 Jan 3 14:12 grass-6.0.2RC3.md5sum
> > 8655932 Jan 3 14:12 grass-6.0.2RC3.tar.gz
> > 6687 Jan 3 14:12 INSTALL
> > 6489 Jan 3 14:12 REQUIREMENTS.html
> > 10343 Jan 3 14:12 SUBMITTING
> > It will be available from the mirror sites within
> > 48h from now.
> > New in RC3:
> > * bugfix for 'builddemolocation target' in Makefile
> > when building as root (RPMs etc)
> > * version year fixed to 2006
> > Please test as much as possible. If everything works
> > as expected, we can release it officially, otherwise
> > a release candidate 4 will be necessary.
> > Announcement with list of changes:
> > http://grass.itc.it/announces/announce_grass602.html
> > Best regards
> > Markus
> > grass5 mailing list
> > grass5 at grass.itc.it
> > http://grass.itc.it/mailman/listinfo/grass5
> grass5 mailing list
