[GRASS5] [bug #3966] (grass) Refernce to -z option in r.slope.aspect is obsolete
Request Tracker grass-bugs at intevation.de
Sat Jan 7 17:37:32 EST 2006
this bug's URL: http://intevation.de/rt/webrt?serial_num=3966
Subject: Refernce to -z option in r.slope.aspect is obsolete
Platform: GNU/Linux/i386
grass obtained from: CVS
grass binary for platform: Compiled from Sources
GRASS Version: GRASS 6.1.cvs checked out 20060107
Documentation for r.slope.aspect makes reference to a -z option for rasters that contain valid elevations with VALUE = 0. This appears to be no longer an option (hopefully no longer required)?
Example:
> r.slope.aspect -z elev=dem_60ft aspect=test
Sorry, <z> is not a valid flag
Description:
 Generates raster map layers of slope, aspect, curvatures and partial derivatives from a raster map layer of true elevation values. Aspect is calculated counterclockwise from east.
Usage:
 r.slope.aspect [-aq] elevation=string [slope=string] [format=string]
   [prec=string] [aspect=string] [pcurv=string] [tcurv=string]
   [dx=string] [dy=string] [dxx=string] [dyy=string] [dxy=string]
   [zfactor=value] [min_slp_allowed=value]
Flags:
  -a   Do not align the current region to the elevation layer
  -q   Quiet
<snip>
David Finlayson
david.p.finlayson at gmail.com
-------------------------------------------- Managed by Request Tracker
