[GRASS5] NVIZ fails to build on an up-to-date Ubuntu Hoary
Bob Covill bcovill at tekmap.ns.ca
Sun Jan 8 16:23:31 EST 2006
I do not know if this helps or not. I googled the OPenGL library eror
listed below and found the following thread ...
http://ubuntuforums.org/archive/index.php/t-18977.html
among others
To solve the problem it sounds like they installed the xxf86mv-dev
package, and added -lXxf86mv to the library list.
Hope this helps.
Bob
Maciek Sieczka wrote:
> Hi,
> No matter what I do, NVIZ deosn't build in any Grass 6.0 or 6.1 I try on
> my Ubuntu Hoary. Can any Hoary user please check if it works for him?
> The error I'm continously getting is:
> maciek at sorbus:~/src/straight/grass6/visualization/nviz$ make
> cd src ; make
> make[1]: Entering directory
> `/home/maciek/src/straight/grass6/visualization/nviz/src'
> gcc -Wl,--export-dynamic -L/home/maciek/src/straight/grass6/dist./lib
> -Wl,-rpath-link,/home/maciek/src/straight/grass6/dist./lib
> -o /home/maciek/src/straight/grass6/dist./bin/nviz OBJ./nvizAppInit.o
> OBJ./change_view.o OBJ./draw.o OBJ./exag.o OBJ./glwrappers.o
> OBJ./init_commands.o OBJ./lights.o OBJ./map_obj.o OBJ./misc.o
> OBJ./nviz_init.o OBJ./position.o OBJ./quick_draw.o OBJ./anim_support.o
> OBJ./cutplane_obj.o OBJ./script_support.o OBJ./do_zoom.o OBJ./label.o
> OBJ./nvizMain.o OBJ./togl.o OBJ./togl_cb.o OBJ./query_vect.o
> OBJ./volume.o OBJ./togl_flythrough.o  -lgrass_ogsf -lgrass_image \
> -lgrass_bitmap -lgrass_linkm -lgrass_vect -lgrass_dig2 -lgrass_dgl
> -lgrass_rtree -lgrass_linkm -lgrass_dbmiclient -lgrass_dbmibase
> -L/usr/local/lib -lgdal -lgrass_sites  -lgrass_form -lgrass_dbmiclient
> -lgrass_dbmibase  \
> -lgrass_gis -lgrass_datetime -lz    -lm  -lz  \
> -lgrass_datetime   -ltk8.3 -lm  -ltcl8.3 -lm -lGLU  -lGL -lpthread  -lSM
> -lICE -lX11 -lXmu -lXext -lm  -ldl -lz   -L/usr/X11R6/lib  -ltiff  \
>   -lSM -lICE -lX11 -lgrass_g3d
> /usr/X11R6/lib/libGL.a(glxcmds.o)(.text+0x2eea): In function
> `glXGetMscRateOML':: undefined reference to `XF86VidModeQueryVersion'
> /usr/X11R6/lib/libGL.a(glxcmds.o)(.text+0x2f1a): In function
> `glXGetMscRateOML':: undefined reference to `XF86VidModeGetModeLine'
> collect2: ld returned 1 exit status
> make[1]: *** [/home/maciek/src/straight/grass6/dist./bin/nviz] Error 1
> make[1]: Leaving directory
> make: *** [nvwish] Error 2
> The ./configure was:
> --with-cxx
> --without-odbc
> --enable-largefile
> --with-sqlite
> --with-tcltk-includes="/usr/include/tcl8.3/" "/usr/include/tk8.3/"
> --with-postgres-includes="/usr/include/postgresql/"
> --with-freetype
> --with-freetype-includes="/usr/include/freetype2/"
> The last succesfull Grass 6.1 CVS build on my machine was on 2005-11-16.
> However, now the 2005-11-16 CVS revision fails. Thus I assume something
> that was introduced to my system since 2005-11-16 causes the problem. I
> have no idea what this exactly could be though. Since then I have been
> updating my machine several times, keeping it always up to date.
> Eg. the kernel revision changed. On 2005-11-16 it was:
> linux-image-2.6.10-5-686 (2.6.10-34.7)
> Now it's:
> linux-image-2.6.10-6-686 (2.6.10-34.8)
> And I'm mentioning it because of what I learned form Markus Neteler:
> Markus Neteler wrote:
>>isn't it strange that there is no architecture?
>>It should be
>>.../grass6/dist.i686-pc-linux-gnu/lib ...
> What do you think of it?
> I can't build NVIZ anymore which I have to use often. No good. Please
> help.
> Maciek
> W polskim Internecie s± setki milionów stron. My przekazujemy Tobie tylko najlepsze z nich!
> http://katalog.panoramainternetu.pl/
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
