[GRASS5] [bug #3974] (grass) r.mapcalc/libgis failure with LFS enabled
Markus Neteler via RT grass-bugs at intevation.de
Tue Jan 10 08:27:38 EST 2006
An addition,
it probably only happens when having set
 export GRASS_INT_ZLIB=1
before starting GRASS. In this case it would be
the combination of ZLIB compression for Integer files
and LFS enabled.
Markus
-------------------------------------------- Managed by Request Tracker
