[GRASS5] [bug #3973] (grass) ./configure: FORTRAN compiler not set
Markus Neteler
neteler at itc.it
Wed Jan 11 03:56:25 EST 2006
On Tue, Jan 10, 2006 at 06:23:07PM +0000, Glynn Clements wrote:
> Markus Neteler wrote:
> > > > this bug's URL: http://intevation.de/rt/webrt?serial_num=3973
> > > > Subject: ./configure: FORTRAN compiler not set
> > > The check was disabled in configure.in:
> > > revision 1.65
> > > date: 2004/11/29 09:17:58; author: markus; state: Exp; lines: +1 -1
> > > disabled F77 as not needed
> > See
> > http://intevation.de/rt/webrt?serial_num=2731
> > You suggested to (probably) remove it:
> > Glynn Clements glynn at gclements.plus.com
> > Sun, 28 Nov 2004 05:18:33 +0000
> > "The configure check should probably be removed."
> > http://grass.itc.it/pipermail/grass5/2004-November/016200.html
> > > lib/cdhc still has some Fortran files, but they aren't used.
> > So, do we want it back? Doesn't it confuse people who do not have
> > Fortran installed (such as the ongoing BLAS/LAPACK confusion)?
> At a minimum, while the f77/g77 check in configure.in is disabled, the
> "FORTRAN compiler" message should also be disabled.
> Also, if the Fortran files in lib/cdhc are no longer necessary, they
> Glynn Clements <glynn at gclements.plus.com>
Someone may to submit necessary changes.
Markus
