[GRASS5] r.in.wms
Jachym Cepicky
jachym.cepicky at centrum.cz
Tue Jan 17 13:39:50 EST 2006
Hallo,
I'm sending new version of r.in.wms. I added new option "-l" for listing
avaliable layers on the server (very primitive). I also made safer cleaning of temporary
files -- it should not harm any more ...
I hope, it will work on other servers -- it worked for two, which are
iteresting for me, very well.
I hope, this script is good start for basic support of WMS in GRASS.
If nobody will have any objections, I would add it to GRASS-Addons site.
Jachym
On Mon, Jan 16, 2006 at 04:00:46PM +1300, Hamish wrote:
> > For every body, who is using this script: it could destroy your .*
> > files! I'm really sorry, for annoucing this.
> > If the variable $IMAGEFILE is not set, the script could start to
> > remove all '.*' files in current directory -- see line 67 of the
> > script. It should not happen. But it could, I'm not by the linux
> > machine now, to test the conditions...
> > I'm working on new version, which is able to pool avaliable layers
> > from the server first (GetCapabilities) and in this version, I will
> > take more care about it.
> If it is possible, it is good to create, cd, and install files into a TMP
> grass directory using the g.tempfile module. This makes it harder to make
> these sorts of mistakes and if the script is aborted any left over files
> are automatically cleaned when you leave grass.
> see the v.in.garmin and r.in.srtm scripts for examples.
> > If you are using the script, pleace, change the line 67 for example to
> > if [ "${IMAGEFILE}" != "" ]; then
> > rm -iv ${IMAGEFILE}.*
> > fi
> better for cross-platform portability:
> if [ -n "${IMAGEFILE}" ]; then
> (-n means non-zero, == "" is -z)
> [SUBMITTING_SCRIPTS file updated in 6.1 CVS]
> Hamish
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
Jachym Cepicky
e-mail: jachym.cepicky at centrum.cz
URL: http://les-ejk.cz
Type: application/x-gtar
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20060117/b7fc3e73/r.in.wms.gtar
