[GRASS5] [bug #4004] (grass) d.vect: where clause does not function for layer 2 table
Request Tracker grass-bugs at intevation.de
Tue Jan 17 15:17:11 EST 2006
this bug's URL: http://intevation.de/rt/webrt?serial_num=4004
Subject: d.vect: where clause does not function for layer 2 table
Platform: GNU/Linux/x86
grass obtained from: Trento Italy site
grass binary for platform: Compiled from Sources
GRASS Version: CVS 20060116
When two tables are connected to a vector, it is not possible to use a where clause to filter features based on the table attached to layer 2.
i.e.
v.db.connect map table=t1 layer=1
v.db.connect map table=t2 layer=2
#works as expected
d.vect map where="t1.col = 1" layer=1
#produces no output
d.vect map where="t2.col = 1" layer=2
This is with the MySQL driver.
Thanks,
Dylan
-------------------------------------------- Managed by Request Tracker
