[GRASS5] winGRASS: mingw32 and execl (g.list)
Glynn Clements
glynn at gclements.plus.com
Sun Jan 22 04:39:59 EST 2006
Markus Neteler wrote:
> Now a question: While 'g.list' compiled, it just does not display
> anything and exits. May execl() be the problem?
> general/manage/cmd/list.c
Possibly. mon.start uses spawnl() instead:
#ifdef __W98__
#include <process.h>
#define execl(fullpath,path,name,bg,link,nul) \
do { \
spawnl(_P_DETACH,fullpath,path,name,"-",link,nul); \
return 0; \
} while (0)
#endif /* __W98__ */
However, if list.c compiles and links, something is providing an
execl() function.
It seems more likely that the access() check is failing. Maybe the
lister program has a ".exe" suffix cauing it not to be found?
Ideally, libgis needs a standard interface for command execution.
There is already a (mostly untested) Unix implementation in
lib/gis/spawn.c. A Windows implementation would need to use
CreateProcess instead.
> Or do we have to implement some .../path/... vs ...\path\...
> tricks there?
Nope; it isn't related to path handling.
FWIW, I will be able to help on Windows issues shortly. The reason why
I haven't been around much is that I've just got a new PC (running
Windows XP Pro), and I've been rather busy setting it up and
re-learning how to use Windows.
