[GRASS5] [bug #4037] (grass) d.vect.thematic: fails to generate a legend for >20 custom_breaks
Request Tracker
grass-bugs at intevation.de
Tue Jan 24 08:29:46 EST 2006
this bug's URL: http://intevation.de/rt/webrt?serial_num=4037
Subject: d.vect.thematic: fails to generate a legend for >20 custom_breaks
Platform: GNU/Linux/x86
grass obtained from: Trento Italy site
grass binary for platform: Compiled from Sources
GRASS Version: cvs 2005.01.10
d.vect.thematic map=rogow_parcels_01 type=area column=CODE themetype=graduated_colors themecalc=custom_breaks 'breakpoints=1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21' layer=1 icon=basic/circle size=5 maxsize=20 nint=4 colorscheme=green-red pointcolor=255:128:1 linecolor=0:0:0 startcolor=255:128:255 endcolor=255:255:255 monitor=x1 -l
Thematic map legend for column CODE of map rogow_parcels_01
Value range: 1.000000 - 666.000000
Color(R:G:B) Value
0:255:0 1 - 2
13:242:0 2 - 3
26:229:0 3 - 4
39:216:0 4 - 5
52:203:0 5 - 6
65:190:0 6 - 7
78:177:0 7 - 8
91:164:0 8 - 9
104:151:0 9 - 10
117:138:0 10 - 11
130:125:0 11 - 12
143:112:0 12 - 13
156:99:0 13 - 14
169:86:0 14 - 15
182:73:0 15 - 16
195:60:0 16 - 17
208:47:0 17 - 18
221:34:0 18 - 19
234:21:0 19 - 20
255:0:0 20 - 21
GRASS_INFO_WARNING(3623,1): Problem parsing command [8 -1]
GRASS_INFO_WARNING(3623,2): Problem parsing command [5 -1]
>20 custom_breaks are supported in general. Only that -l switch cannot be used along.
Maciek
-------------------------------------------- Managed by Request Tracker
