[GRASS5] Re: [Qgis-developer] Windows port continues
Radim Blazek radim.blazek at gmail.com
Thu Jan 26 03:57:18 EST 2006
On 1/26/06, Tim Sutton <tim at linfiniti.com> wrote:
> Hi Radim
> I tested it under windows. What I could use works really nicely.
> However I think the lib dir is missing from your zip file or something
> as both providers and plugins are not. found.
You are right, sorry. Here you can download grass provider and plugin:
  http://mpa.itc.it/radim/wingrass/tmp/grassplugin.dll
  http://mpa.itc.it/radim/wingrass/tmp/grassprovider.dll
put them into qgis-0.8-preview-win32-060125/lib/qgis
and you should be able to load grass plugin. It will ask you for
GISBASE which is /your_path/qgis-0.8-preview-win32-060125/grass
It is not perfect, e.g. new location wizard crashes on projection selection,
digit works but it has some problems.
Radim
> This is really brilliant!
> Regards
> Tim
> > Hi
> > Well done Radim! I'm going to do the unthinkable and reboot my pc
> > into windows just to try this out!
> > Regards
> > Tim
> > Radim Blazek wrote:
> >> Hi,
> >> I was able to compile QGIS + GRASS plugin for Windows. Here are
> >> some snapshots: http://mpa.itc.it/radim/wingrass/qgis-win10.png
> >> http://mpa.itc.it/radim/wingrass/qgis-win11.png
> >> http://mpa.itc.it/radim/wingrass/qgis-win12.png
> >> http://mpa.itc.it/radim/wingrass/qgis-win13.png
> >> You can download preview binary but it is big (70MB) and it is
> >> not yet stable: http://mpa.itc.it/radim/wingrass/
> >> Updated instructions for compilation:
> >> http://mpa.itc.it/radim/wingrass/INSTALL
> >> Radim
> >> ------------------------------------------------------- This
> >> SF.net email is sponsored by: Splunk Inc. Do you grep through
> > log files
> >> for problems? Stop! Download the new AJAX search engine that
> >> makes searching your log files as easy as surfing the web.
> >> DOWNLOAD SPLUNK!
> >> http://sel.as-us.falkag.net/sel?cmd=k&kid3432&bid#0486&dat1642
> >> _______________________________________________ Qgis-developer
> >> mailing list Qgis-developer at lists.sourceforge.net
> >> https://lists.sourceforge.net/lists/listinfo/qgis-developer
> > -- Tim Sutton (tim at linfiniti.com)
> > Visit http://qgis.org for a great open source GIS application Skype
> > : timlinux Jabber : timlinux at jabber.org MSN : tim_bdworld at msn.com
> > ICQ : 245485851
> This SF.net email is sponsored by: Splunk Inc. Do you grep through log
> files
> for problems?  Stop!  Download the new AJAX search engine that makes
> searching your log files as easy as surfing the  web.  DOWNLOAD SPLUNK!
> http://sel.as-us.falkag.net/sel?cmd=lnk&kid=103432&bid=230486&dat=121642
> Qgis-developer mailing list
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.2.1 (MingW32)
> Comment: Using GnuPG with Thunderbird - http://enigmail.mozdev.org
> iD8DBQFD2Ay4WvXTJUo0BDoRAk7FAJ9H1DvWLYmSZ6LzygqR+hb6wznvqACcCag2
> Ph48Z0YWK8DuM90f/DKd8kA=
> =71rl
> -----END PGP SIGNATURE-----
