[GRASS5] GPJ_osr_to_grass
Radim Blazek
radim.blazek at gmail.com
Fri Jan 27 09:56:25 EST 2006
Hi Paul,
in the header of GPJ_osr_to_grass there is a parameter
OGRSpatialReferenceH *hSRS:
int GPJ_osr_to_grass(struct Cell_head *cellhd, struct Key_Value **projinfo,
struct Key_Value **projunits, OGRSpatialReferenceH *hSRS,
int interacti)
but in the body it is used as OGRSpatialReferenceH not OGRSpatialReferenceH*,
for example OSRMorphFromESRI( hSRS ) which is defined as
OGRErr OSRMorphFromESRI( OGRSpatialReferenceH hSRS )
The parameter should be changed to OGRSpatialReferenceH hSRS
or should it be used in the body as *hSRS? It seems that in GRASS
is the function called with OGRSpatialReferenceH*.
How can it work on Linux? On Windows it either crashes if
the parameter is passed as (void **) OGRSpatialReferenceH or
does not work if passed as OGRSpatialReferenceH*.
Radim
