[GRASS5] [bug #4044] (grass) v.to.db: manual suggests 'type=area', however 'Error: value <area> out of range'
Request Tracker grass-bugs at intevation.de
Fri Jan 27 10:32:12 EST 2006
this bug's URL: http://intevation.de/rt/webrt?serial_num=4044
Subject: v.to.db: manual suggests 'type=area', however 'Error: value <area> out of range'
Platform: GNU/Linux/x86
grass obtained from: CVS
grass binary for platform: Compiled from Sources
GRASS Version: CVS 2005.01.27
EXAMPLES section contains following:
v.to.db map=soils type=area option=cat
v.to.db map=soils type=area option=area col=area_size unit=h
But this yields:
Error: value <area> out of range for parameter <type>
Is it a mistake in documentation or is v.to.db supposed to support type=area (that would make sense...)?
Maciek
-------------------------------------------- Managed by Request Tracker
