[GRASS5] over 300 errors - can't build CVS 2005.01.29
Maciek Sieczka werchowyna at epf.pl
Sun Jan 29 18:02:30 EST 2006
Using Ubuntu 5.10 Breezy, gcc 3.4.4. Plenty of other stuff, all either
CVS or newest releases, built fine today (hdf4, proj, geos, postgis,
sqlite, gdal).
My ./configure:
--with-cxx
--without-odbc
--with-sqlite
--with-tcltk-includes="/usr/include/tcl8.3/"
--with-postgres-includes="/usr/include/postgresql/"
--with-freetype
--with-freetype-includes="/usr/include/freetype2/"
--with-readline
$ cat error.log
GRASS GIS compilation log
Started compilation: nie sty 29 22:26:50 CET 2006
Errors in:
/home/fishoo/src/straight/grass6/lib/gis
/home/fishoo/src/straight/grass6/lib/gmath
/home/fishoo/src/straight/grass6/lib/raster
/home/fishoo/src/straight/grass6/lib/display
/home/fishoo/src/straight/grass6/lib/D
/home/fishoo/src/straight/grass6/lib/db/dbmi_base
/home/fishoo/src/straight/grass6/lib/db/dbmi_client
/home/fishoo/src/straight/grass6/lib/db/stubs
/home/fishoo/src/straight/grass6/lib/db/dbmi_driver
/home/fishoo/src/straight/grass6/lib/edit
/home/fishoo/src/straight/grass6/lib/form
/home/fishoo/src/straight/grass6/lib/imagery
/home/fishoo/src/straight/grass6/lib/proj
/home/fishoo/src/straight/grass6/lib/segment
/home/fishoo/src/straight/grass6/lib/vector/diglib
/home/fishoo/src/straight/grass6/lib/vector/Vlib
/home/fishoo/src/straight/grass6/lib/sites
/home/fishoo/src/straight/grass6/lib/rst/interp_float
<snip>
# 300 more here
</snip>
Finished compilation: nie sty 29 22:33:04 CET 2006
(In case of errors please change into the directory with error and run
'make')
3 error examples:
$ cd /home/fishoo/src/straight/grass6/lib/gis ; make make: *** No rule
to make target `OBJ.i686-pc-linux-gnu/sample.o', needed by
`/home/fishoo/src/straight/grass6/dist.i686-pc-linux-gnu/lib/libgrass_gis.6.1.cvs.so'.
Stop.
$ cd /home/fishoo/src/straight/grass6/lib/gmath ; make
gcc -shared
-o /home/fishoo/src/straight/grass6/dist.i686-pc-linux-gnu/lib/libgrass_gmath.6.1.cvs.so
-Wl,--export-dynamic
-L/home/fishoo/src/straight/grass6/dist.i686-pc-linux-gnu/lib
-Wl,-rpath-link,/home/fishoo/src/straight/grass6/dist.i686-pc-linux-gnu/lib
OBJ.i686-pc-linux-gnu/brent.o OBJ.i686-pc-linux-gnu/dalloc.o
OBJ.i686-pc-linux-gnu/del2g.o OBJ.i686-pc-linux-gnu/eigen.o
OBJ.i686-pc-linux-gnu/eigen_tools.o OBJ.i686-pc-linux-gnu/fft.o
OBJ.i686-pc-linux-gnu/gauss.o OBJ.i686-pc-linux-gnu/getg.o
OBJ.i686-pc-linux-gnu/ialloc.o OBJ.i686-pc-linux-gnu/jacobi.o
OBJ.i686-pc-linux-gnu/la.o OBJ.i686-pc-linux-gnu/lu.o
OBJ.i686-pc-linux-gnu/max_pow2.o OBJ.i686-pc-linux-gnu/mult.o
OBJ.i686-pc-linux-gnu/rand1.o OBJ.i686-pc-linux-gnu/svd.o -lgrass_gis
-lgrass_datetime -lz    -lfftw -lm   && if [ -z "" ] ; then ln -f -s
libgrass_gmath.6.1.cvs.so /home/fishoo/src/straight/grass6/dist.i686-pc-linux-gnu/lib/libgrass_gmath.so;
fi /usr/bin/ld: cannot find -lgrass_gis collect2: ld returned 1 exit
status make: ***
[/home/fishoo/src/straight/grass6/dist.i686-pc-linux-gnu/lib/libgrass_gmath.6.1.cvs.so]
Error 1
$ cd /home/fishoo/src/straight/grass6/raster/r.los ; make gcc
-DPACKAGE=\""grassmods"\"
-o /home/fishoo/src/straight/grass6/dist.i686-pc-linux-gnu/bin/r.los
OBJ.i686-pc-linux-gnu/color_rnge.o OBJ.i686-pc-linux-gnu/delete.o
OBJ.i686-pc-linux-gnu/main.o OBJ.i686-pc-linux-gnu/make_list.o
OBJ.i686-pc-linux-gnu/make_point.o OBJ.i686-pc-linux-gnu/mark_pts.o
OBJ.i686-pc-linux-gnu/pts_elim.o OBJ.i686-pc-linux-gnu/segment.o
-lgrass_segment -lgrass_gis -lgrass_datetime -lz    -lm
-lz /usr/bin/ld: cannot find -lgrass_segment collect2: ld returned 1
exit status make: ***
[/home/fishoo/src/straight/grass6/dist.i686-pc-linux-gnu/bin/r.los]
Error 1
I wanted to attach the make.log, but it's over 60 KB bzipped and the
message gets rejected. Only config.log attached, if this helps somehow.
Maciek
Szukasz do?wiadczonej firmy poligraficznej? Zale?y Ci na terminowo?ci i atrakcyjnych cenach?
Zapraszamy do nas!
http://www.foldruk.pl/
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20060130/613c5e2e/config.log.obj
