[GRASS5] dbmi: db_open_insert_cursor() not implemented
Radim Blazek radim.blazek at gmail.com
Mon Jan 30 03:34:14 EST 2006
The functions db_init_cursor, db_set_cursor_type_insert etc.
are not implemented in db drivers and SQL commands
are executed by db_execute_immediate.
It is certainly desirable to implement that functions and avoid
SQL command strings passed to drivers. It can improve performance
and resolve possible problems with floating points in some drivers.
Radim
On 1/27/06, Roberto Antolin <roberto at geomatica.como.polimi.it> wrote:
> Hi all,
> I'm both a newbie programmer and a newbie GRASS60 user. I'm trying to
> open a cursor with the db_open_insert_cursor function in the next way:
> db_open_insert_cursor (driver, cursor);
> Before that, I've initialized the cursor:
> db_init_cursor (cursor);
> set the cursor's type:
> db_set_cursor_type_insert (cursor);
> and set the driver by default.
> And using GDB, I get the next message:
> Where is my mistake? If there is no error, what's happening?
> Thank you all,
> Roberto.
> Ps: Did I write my massege in the correct list? I hope so.
> Roberto Antolin Sanchez
> Politecnico di Milano – Polo Regionale di Como
> Via Valleggio, 11 – 22100 Como, Italy
> tel: +39 031 3327533
> email: roberto.antolin at polimi.it
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
