[GRASS5] error r.in.gdal v.in.ogr
Otto Dassau dassau at gdf-hannover.de
Tue Jan 31 09:37:27 EST 2006
I tried to import an ERDAS/Img and MapInfo file with a current GRASS and gdal
CVS version and got following similar error message (segmentation fault) for
both commands:
r.in.gdal in=3479060700.img out=muell
v.in.ogr in=test.MIF out=muell
strace r.in.gdal in=3479060700.img out=muell
_llseek(4, 15611, [15611], SEEK_SET)    = 0
close(3)                                = 0
munmap(0x40c9e000, 32768)               = 0
open("/usr/local/grass-6.1.cvs/etc/ogr_csv/gdal_datum.csv", O_RDONLY) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=107157, ...}) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) =
0x40c9e000
_llseek(3, 0, [0], SEEK_CUR)            = 0
read(3, "\"DATUM_CODE\",\"DATUM_NAME\",\"DATUM"..., 4096) = 4096
read(3, "dations v5.1 April 1994.\",EPSG,\""..., 4096) = 4096
read(3, " metres below Hong Kong Principa"..., 4096) = 4096
read(3, "ased on Airy Modified 1849 ellip"..., 4096) = 4096
read(3, ",geodetic,,,7020,8901,1263,Not a"..., 4096) = 4096
read(3, "2 Definition) ellipsoid)\",geodet"..., 4096) = 4096
read(3, "itude: 31 deg 23 min 59.19 sec N"..., 4096) = 4096
read(3, " 02 min 05.1 sec W (of Greenwich"..., 4096) = 4096
read(3, "he Unified Trigonometrical Cadas"..., 4096) = 4096
read(3, "National Geodetic System.] Super"..., 4096) = 4096
read(3, "ion of station Divis. Scale and "..., 4096) = 4096
read(3, "in 07.110 sec N; Longitude: 31 d"..., 4096) = 4096
read(3, "a_1957\"\n6218,Bogota 1975,geodeti"..., 4096) = 4096
read(3, " 00:00:00\",,0,\"D_Fahud\"\n6233,Gan"..., 4096) = 4096
read(3, "1995-06-02 00:00:00\",,0,\"D_Lake\""..., 4096) = 4096
read(3, "orth American Datum 1927,geodeti"..., 4096) = 4096
read(3, "de: 4 deg 47 min 00.10 sec S; Lo"..., 4096) = 4096
read(3, " to best mean fit 9 stations of "..., 4096) = 4096
read(3, " deg 17 min 41.06 sec E (of Gree"..., 4096) = 4096
read(3, "hic mapping.,,Ordnance Survey of"..., 4096) = 4096
read(3, ".80 +/- 0.08 sec W).\",1969,7050,"..., 4096) = 4096
read(3, "els 1972,geodetic,\"Fundamental p"..., 4096) = 4096
read(3, "SG,\"2002-11-29 00:00:00\",,0,\n665"..., 4096) = 4096
read(3, ",,0,\n6659,Islands Network 1993,g"..., 4096) = 4096
read(3, ":00:00\",2000.20 2003.361,0,\"D_Bo"..., 4096) = 4096
read(3, " Prague.\",EPSG,\"2001-08-28 00:00"..., 4096) = 4096
read(3, "s standards manual, 1974.\",EPSG,"..., 4096) = 661
read(3, "", 4096)                       = 0
close(3)                                = 0
munmap(0x40c9e000, 4096)                = 0
--- SIGSEGV (Segmentation fault) @ 0 (0) ---
gdalinfo and ogrinfo work fine - so it's probably in GRASS?
regards,
 Otto
