[GRASS-dev] portable.h alternatives? [was: include/portable.h?]
William Kyngesburye
woklist at kyngchaos.com
Sat Jul 1 15:07:15 EDT 2006
On Jul 1, 2006, at 1:58 PM, Glynn Clements wrote:
> The ideal solution would be to re-write portable.c so that it doesn't
> depend upon the host's byte order; i.e. [de]serialize in the correct
> byte-order to start with, rather than assuming that the host's
> byte-order matches that of the file then "byte-swap" if it doesn't.
Maybe I should add a wish for this? Or could you, since you seem to
understand what to ask for?
This is the only place I've found in GRASS right now with endian-
dependent code. Could something like this make it into the 6.2 release?
William Kyngesburye <kyngchaos at kyngchaos.com>
http://www.kyngchaos.com/
"Those people who most want to rule people are, ipso-facto, those
least suited to do it."
- A rule of the universe, from the HitchHiker's Guide to the Galaxy
