[GRASS-dev] [bug #4768] (grass) nviz segfault on startup when
creating display window
Glynn Clements
glynn at gclements.plus.com
Mon Jul 3 11:42:02 EDT 2006
Michael Barton wrote:
> >> If I add an elevation raster from spearfish6 demo, it shows some status, then
> >> crashes with the same
> >> thread trace when trying to create the window.
> > This is a bug in the system's OpenGL implementation; there isn't
> > anything we can do about it.
> Should people using Intel Macs install a different version of OpenGL?
It's worth a try. Even if nothing else works, Mesa should (although it
will be a lot slower).
