[GRASS-dev] GRASS 6.1.0 release preparation
Markus Neteler neteler at itc.it
Tue Jul 4 09:57:21 EDT 2006
On Tue, Jul 04, 2006 at 12:26:16AM -0400, Helena Mitasova wrote:
> Some modules have problems running on 64bit (maybe that is also
> #4725?
The nviz volume bug was recently introduces, I think. As far
as I remember it worked some time ago on 64bit.
https://intevation.de/rt/webrt?serial_num=4725
  I followed "mode" into lib/ogsf/GVL2.c GVL_slice_get_drawmode()
  and then *gvl to gvl_get_vol() in lib/ogsf/gvl.c, but then I get lost.
> but it is for sure #4546
https://intevation.de/rt/webrt?serial_num=4546
r.sim.water crashes in simlib/input.c line 403, function grad_check():
 if (cchez[k][l] != 0.) {
   with k=700 and l=0
Not sure why.
> and supposedly also r.sun - probably due to uninitialized
> variables).
Right, It crashes in INPUT () at main.c:656
              if (z[i][j] == UNDEFZ || o[i][j] == UNDEFZ || s[i][j] == UNDEFZ)
Here a Spearfish test script:
ELEV=elevation.dem
TMP=$$
SLOPE=$TMP.slope
ASP=$TMP.aspect
r.slope.aspect elevation.dem as=$TMP.aspect sl=$TMP.slope --o
r.mapcalc global_shadow.rad=0
DAY=055
r.sun -s elevin=elevation.dem aspin=$TMP.aspect slopein=$TMP.slope day=$DAY \
      beam_rad=bs_rad.$DAY diff_rad=ds_rad.$DAY refl_rad=rs_rad.$DAY
> I don't think that this should stop the release.
I would appreciate if those two bugs would be fixed, but we
can backport the fixes later.
> Also I believe that we should thoroughly test gis.m before release -
> we were getting all kinds of error messages but I think that it all
> has been fixed by now.
Yes, gis.m should get a consolidation cycle now.
Markus
