[GRASS-dev] v.in.gpsbabel
Markus Neteler
neteler at itc.it
Tue Jul 4 10:21:01 EDT 2006
On Tue, Jul 04, 2006 at 04:11:43PM +0200, Paolo Cavallini wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi all.
> Just a small note about v.in.gpsbabel: when loading data to DB, if user
> does not have sufficient permissions, he gets an error about db.login.
Probably an error test is missing? Could you post the error message?
BTW: db.login is only needed for real DBMS'.
> In fact, the problem can be solved both with db.login and db.connect, so
> I think a more general statement would be more appropriate.
> Should I fill a bug about this?
Aren't the authors in cc? :-)
Markus
> All the best.
> pc
> Paolo Cavallini
> email+jabber: cavallini at faunalia.it
> www.faunalia.it
> Piazza Garibaldi 5 - 56025 Pontedera (PI), Italy Tel: (+39)348-3801953
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.3 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
> iD8DBQFEqncf/NedwLUzIr4RAjMzAJ0QcHeXPuHQ456TZZT/XfUhWPWuswCfQY4A
> bEk5gzVdzk98mZXt2J8lTws=
> =9gzg
> -----END PGP SIGNATURE-----
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
Markus Neteler <neteler itc it> http://mpa.itc.it/markus/
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
