[GRASS-dev] [bug #3877] (grass) r.to.vect,
v.in.ascii use too much memory for millions of points
Maciek Sieczka via RT
grass-bugs at intevation.de
Wed Jul 5 14:39:04 EDT 2006
Markus wrote:
> New patch submitted, see
> https://intevation.de/rt/webrt?serial_num=3354&display=History
> Does it solve the problem?
So I checked with current CVS and the same problem still applies to r.to.vect.
"r.to.vect -z feature=point input=dem_5 output=dem_5_pt" eats up all 1GB RAM +
1GB SWAP at about 5 000 000 points.
The above mentioned Andrew Danner's fix for v.in.ascii is great stuff but
r.to.vect problem remains (in my bug report I was complaining about only
r.to.vect, few days later Hamish changed the subject, as v.in.ascii issue
popped up during discussion).
Is it possible that r.to.vect suffers from a similar problem as v.in.ascii
did, so a similar fix would do? Andrew?
Maciek
-------------------------------------------- Managed by Request Tracker
