[GRASS-dev] Re: [GRASS-user] can't use r.recode from standart GUI
Glynn Clements
glynn at gclements.plus.com
Thu Jul 6 00:46:51 EDT 2006
Nicolas Devaux wrote:
> I'm trying to use the r.recode fonction via the GUI (raster, change
> categories values.../recode categories using rules). When I launch the
> fonction, proper window opens, but when I click run, a terminal window
> strart to open and close very quickly. Hence, I can't notify new values
> to use for recoding the raster map. If I use the r.recode fonction from
> the Grass terminal, everything is working properly...
> Does someone have any tip for this problem?
There are several possible fixes/workarounds:
1. Use the "Recode categories using rules file" option instead; that
reads the rules from a file, rather than from a terminal.
2. Add the path to the GRASS library directory (e.g.
/usr/local/grass6/lib) to /etc/ld.so.conf, then run "ldconfig".
3. Change the last line of the etc/gm/script/r.recode.rules script to:
exec xterm -e $GISBASE/etc/grass-run.sh r.recode input=$GIS_OPT_INPUT output=$GIS_OPT_OUTPUT
Also, I'll commit a fixed r.recode.rules script to CVS.
