[GRASS-dev] current CVS: v.in.ogr doesn't build
Fri Jul 7 14:39:00 EDT 2006
Maciek Sieczka wrote:
> CVS fetched just a while ago:
> Errors in:
> /home/fishoo/src/straight/grass6/vector/v.in.ogr
> $ cd /home/fishoo/src/straight/grass6/vector/v.in.ogr
> $ make
> gcc -I/home/fishoo/src/straight/grass6/dist.i686-pc-linux-gnu/include
> -g -O2  -I/usr/local/include     -DPACKAGE=\""grassmods"\"
> -I/home/fishoo/src/straight/grass6/dist.i686-pc-linux-gnu/include \ -o
> OBJ.i686-pc-linux-gnu/main.o -c main.c main.c: In function `main':
> main.c:632: error: `OFTDate' undeclared (first use in this function)
> main.c:632: error: (Each undeclared identifier is reported only once
> main.c:632: error: for each function it appears in.) make: ***
> [OBJ.i686-pc-linux-gnu/main.o] Error 1
> Last time I built on 05 July and all was OK. Since then in GRASS-COMMIT
> Markus wrote, on 2006.07.06:
> Modified Files:
> 	main.c
> Log Message:
> 'NULL' support activated for OFTInteger and OFTReal
> Modified Files:
> 	main.c
> Log Message:
> OFTDate added; OFTIntegerList hack polished
You need the most recent version of GDAL/OGR; the NEWS file at:
	http://www.remotesensing.org/gdal/NEWS.html
says:
	OGR 1.3.2 - Overview of Changes
	OGRFeature:
	 - Added support for OFTDate, OFTTime and OFTDateTime field types.
	 - Also applied to a few drivers (shapefile, mysql, postgres)
As 1.3.2 has only been out a couple of months, I doubt that you will
be able to get an "official" package from your distribution vendor yet
(the 1.3.2 ebuild for Gentoo is still masked on all platforms).
