[GRASS-dev] [bug #4524] (grass) v.clean, v.patch (else?): output to stderr instead of stdout...
Mon Jul 10 02:44:10 EDT 2006
Maciek Sieczka wrote:
> > still an issue? the fprintf's have been changed in v.patch.
> Yes.
> v.patch still prints to terminal instead of /dev/null. There is no
> difference to before the change you mention, ie.:
>  $ v.patch input=map1,map2 output=map3 >/dev/null
>  Patching file map1
>  Patching file map2
>  Patch complete. 2 files patched.
>  Intersections at borders will have to be snapped.
>  Lines common between files will have to be edited.
>  The header information also may have to be edited.
> The above 6 lines should all go to /dev/null, too. v.clean is even
> worse - *not a single line* is redirected to /dev/null, so each
> v.clean run results in about 40 lines printed to the terminal.
GRASS sends general messages to stderr and parsable output to stdout.
to redirect stderr to /dev/null do:
G61> v.patch input=map1,map2 output=map3 2> /dev/null
note this will send errors and warnings to /dev/null too, which may not
be what you want.
most modules should be quiet by default (I think ESR asks for "only
display output if something surprising happens"), but include a -v
verbose flag if verbose output could be interesting (e.g. long running
modules). Really long running modules may want to send some heartbeat or
status messages.
> G> v.patch input=map1,map2 output=map3 >/dev/null
>  Patching file map1
>  Patching file map2
These look like they might be put behind a -v verbose flag or
G_debug(1,"");
These look like they should remain with G_message().
Hamish
