[GRASS-dev] [bug #4524] (grass) v.clean, v.patch (else?): output to stderr instead of stdout...
Maciek Sieczka via RT grass-bugs at intevation.de
Wed Jul 12 04:33:45 EDT 2006
Hamish wrote (Mon, Jul 10 2006 11:24:12):
> The correct solution IMO is to relegate overly verbose messages to
> G_debug(1,) or a -v verbose flag, and continue to send warnings and
> errors to stderr.
> > >  Patch complete. 2 files patched.
> in effect G_done_msg().
> > >  Intersections at borders will have to be snapped.
> > >  Lines common between files will have to be edited.
> > >  The header information also may have to be edited.
> These 3 are somewhere between needing Warnings and boldface type in the
> help page. (hence G_message())
> The question might be reduced to "where to send G_message()?" ?
Anywhere but stdout, I think.
Example reason: I don't want somebody using my v.flip (a script that calls
v.patch, among the others) to be confused with v.patch information that:
# Intersections at borders will have to be snapped.
# Lines common between files will have to be edited.
# The header information also may have to be edited.
Because I have taken care of this for the user, knowing what the input for
v.patch is and using 'v.clean tool=snap' as needed. That information above is
simply wrong and confusing the user, when v.patch is a script component.
Maciek
-------------------------------------------- Managed by Request Tracker
