[GRASS-dev] displaying (slightly) broken raster maps in gis.m
Michael Barton
michael.barton at asu.edu
Sat Jul 15 19:05:53 EDT 2006
Glynn,
I've removed all extraneous 'eval exec' syntax from gism I think, with the
exception of the procedures in runandoutput.tcl (attached here for
convenience because it's small). If I try to clean up the run and runcmd
procedures here, d.mon bombs in the gism startup. I don't know whether it is
due to writing to /dev/null or because of d.mon. Could you take a look and
offer any suggestions? Thanks.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Glynn Clements <glynn at gclements.plus.com>
> Date: Sat, 8 Jul 2006 08:49:46 +0100
> To: Michael Barton <Michael.Barton at asu.edu>
> Cc: Hamish <hamish_nospam at yahoo.com>, grass5 <grass-dev at grass.itc.it>
> Subject: Re: [GRASS-dev] displaying (slightly) broken raster maps in gis.m
> Michael Barton wrote:
>>> We noticed gis.m will not display a raster map if the cats/ file is
>>> missing but d.rast will.
>>> is this something to fix, or nothing to worry about?
>>> (mapset was broken after bulk copy via FAT32 external hard drive problems)
>> Gis.m is just a wrapper for d.rast. So I'm not sure why one should display a
>> map and the other one won't.
> gis.m/raster.tcl seems to do a bit more than just run d.rast.
> BTW, looking at that code, I note that the failure to treat commands
> as lists appears to be a common problem within gis.m, e.g.:
> set cmd "d.rast map=$opt($id,1,map)"
> # overlay
> if { $opt($id,1,overlay) } {
> append cmd " -o"
> [snip]
> # raster query
> if { $opt($id,1,rastquery) != "" } {
> append cmd " {$querytype=$opt($id,1,rastquery)}"
> # background color
> if { $opt($id,1,bkcolor) != "" } {
> append cmd " bg=$opt($id,1,bkcolor)"
> Although this particular case should work (certainly, none of the
> arguments can contain spaces, and I don't think that they can contain
> braces), in general you should be using list operations, e.g.:
> set cmd [list d.rast map=$opt($id,1,map)]
> # overlay
> lappend cmd -o
> [snip]
> # raster query
> lappend cmd $querytype=$opt($id,1,rastquery)
> # background color
> lappend cmd bg=$opt($id,1,bkcolor)
> Etc.
> Whilst it is technically sufficient to use list operations only where
> necessary, that requires you to actually consider whether or not they
> are necessary. As most of the time they aren't necessary, overlooking
> the few cases where they /are/ necessary (e.g. filenames, SQL "WHERE"
> clauses etc) becomes almost inevitable.
# LIBRARY: runandoutput.tcl
# AUTHOR(S): Cedric Shock (cedricgrass AT shockfamily.net)
# PURPOSE: Interactive console for gis.m and other run commands
# COPYRIGHT: (C) 2006 GRASS Development Team
# This program is free software under the GNU General Public
# License (>=v2). Read the file COPYING that comes with GRASS
# for details.
#Overloaded gui.tcl behaviour:
# Overload run_cmd (proc called when run button is pushed)
proc run_cmd {dlg} {
global gronsole
global opt
set cmd [dialog_get_command $dlg]
catch {$opt($dlg,run_button) configure -state disabled}
$gronsole run $cmd {} "catch {$opt($dlg,run_button) configure -state active}"
# Bring that output window up:
raise [winfo toplevel $gronsole]
# no output or progress or buttons:
proc make_output {dlg path root} {}
proc make_progress {dlg path root} {}
proc make_buttons {dlg path root} {}
proc make_fun_buttons {dlg path} {
global opt env
set pgm_name $opt($dlg,pgm_name)
set buttonframe [frame $path.buttonframe]
button $buttonframe.run -text [G_msg "Run"] -command "run_cmd $dlg"
# In the future we'll have a button to make a layer from here:
# button $buttonframe.layer -text [G_msg "Layer"] -command "layer_cmd $dlg"
button $buttonframe.help -text [G_msg "Help"] -command "help_cmd $dlg"
button $buttonframe.close -text [G_msg "Close"] -command "close_cmd $dlg"
set opt($dlg,run_button) $buttonframe.run
# Turn off help button if the help file doesn't exist
if {! [file exists $env(GISBASE)/docs/html/$pgm_name.html]} {
$buttonframe.help configure -state disabled
pack $buttonframe.run $buttonframe.help $buttonframe.close \
-side left -expand yes -padx 5 -pady 5
pack $buttonframe -expand no -fill x -side bottom -before [lindex [pack slaves $path] 0]
# Set the starting window size if this is a toplevel window
if {[winfo toplevel $path] == $path} {
wm geometry $path "560x350"
proc run_ui {cmd} {
global dlg path
set program [lindex $cmd 0]
set code [exec -- $program --tcltk]
set path .dialog$dlg
toplevel $path
eval $code
# Push the command to the dialog
set thisdialog $dlg
dialog_set_command $dlg $cmd
# Add our ui
make_fun_buttons $dlg $path
proc run_disabled {gronsole button cmd} {
catch {$button configure -state disabled}
$gronsole run $cmd {running} "catch {$button configure -state active}"
proc gronsole_history {cmdtext ci cmd} {
$cmdtext delete 1.0 end
$cmdtext insert end $cmd
proc command_window {where} {
global keycontrol
set cmdpane [frame $where.command]
set cmdwin [ScrolledWindow $where.win -relief sunken -borderwidth 2]
set gronsole [Gronsole $where.gronsole -clickcmd "gronsole_history $cmdwin.text"]
set cmdtext [text $cmdwin.text -height 4 -width 80]
$cmdwin setwidget $cmdtext
set runbutton [button $cmdpane.run -text [G_msg "Run"] -command "run_disabled $gronsole $cmdpane.run \[string trim \[$cmdtext get 1.0 end\]\]"]
set run2button [button $cmdpane.run2 -text [G_msg "Run (Background)"] -command "$gronsole run \[string trim \[$cmdtext get 1.0 end\]\] {} {}"]
set runuibutton [button $cmdpane.runui -text [G_msg "Run UI"] -command "run_ui \[string trim \[$cmdtext get 1.0 end\]\]"]
set runxterm [button $cmdpane.xterm -text [G_msg "Run in Xterm"] -command "$gronsole run_xterm \[string trim \[$cmdtext get 1.0 end\]\] {}"]
set outpane [frame $where.output]
set savebutton [button $outpane.save -text [G_msg "Save"] -command "$gronsole save"]
set clearbutton [button $outpane.clear -text [G_msg "Clear"] -command "$gronsole clear"]
pack $runbutton $run2button $runuibutton $runxterm \
pack $savebutton $clearbutton \
pack $cmdpane -fill x -side bottom
pack $cmdwin -fill x -side bottom
pack $outpane -fill x -side bottom
pack $gronsole -side top -fill both -expand yes
bind $cmdtext <$keycontrol-c> "tk_textCopy %W"
bind $cmdtext <$keycontrol-v> "tk_textPaste %W"
bind $cmdtext <$keycontrol-x> "tk_textCut %W"
return $gronsole
toplevel .gronsole
wm title .gronsole [G_msg "Output - GIS.m"]
# If we had our own window manager we could withdraw windows instead of iconifying them:
wm protocol .gronsole WM_DELETE_WINDOW "wm iconify .gronsole"
set gronsole [command_window {.gronsole}]
# Run procs for gis.m:
proc execute {cmd} {
# Use run and output
run_ui $cmd
proc spawn {cmd args} {
exec -- $cmd $args &
proc spawn_panel {cmd args} {
global gronsole
$gronsole run $cmd gism {}
proc run_panel {cmd} {
global gronsole
$gronsole run_wait $cmd gism
proc run {cmd args} {
# This and runcmd are being used to run command in the background
# These used to go to stdout and stderr
# but we don't want to pollute that console.
# eval exec -- $cmd $args >@ stdout 2>@ stderr
eval exec -- $cmd $args >& /dev/null
proc runcmd {cmd args} {
global gronsole
set ci [$gronsole annotate $cmd [list gism running]]
eval run $cmd $args
$gronsole remove_tag $ci running
proc term_panel {cmd} {
global gronsole
$gronsole run_xterm $cmd gism
proc term {cmd args} {
global env
exec -- xterm -name xterm-grass -e $env(GISBASE)/etc/grass-run.sh $cmd $args &
# Make sure there's an xmon before running some commands.
# Used in menus.
proc guarantee_xmon {} {
if {![catch {open "|d.mon -L" r} input]} {
while {[gets $input line] >= 0 } {
if {[regexp -nocase {(x[0-9]+).*not running} $line dummy monitor]} {
# $monnum is the monitor number
#create list of non-running monitors
lappend xmonlist $monitor
close $input
set xmon [lindex $xmonlist 0]
spawn "d.mon start=$xmon"
# Annotation procs for gis.m:
proc monitor_annotation_start {mon title tags} {
global gronsole
set handle [$gronsole annotate $title $tags]
$gronsole set_click_command $handle {}
return $handle
proc monitor_annotate {handle text} {
global gronsole
$gronsole annotate_text $handle $text
