[GRASS-dev] Using current grass gui.tcl in python programs.
Michael Barton michael.barton at asu.edu
Sun Jul 16 12:34:32 EDT 2006
I guess I didn't phrase my question correctly. Sorry. Since all GRASS
distributions already have TclTk installed, is there any advantage to
redoing gui.tcl to work in a Tkinter environment for Python testing
purposes? Or are we better off building on the python gui module that Markus
put into the cvs?
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Jachym Cepicky <jachym.cepicky at centrum.cz>
> Date: Sun, 16 Jul 2006 09:08:22 +0200
> To: Michael Barton <michael.barton at asu.edu>
> Cc: Cedric Shock <cedricgrass at shockfamily.net>, <grass-dev at grass.itc.it>
> Subject: Re: [GRASS-dev] Using current grass gui.tcl in python programs.
> If I'm not wrong, Tk goes with standard python distribution for all
> platforms
> jachym
> On Sat, Jul 15, 2006 at 05:39:25PM -0700, Michael Barton wrote:
>> Thanks Cedric.
>> Good to see you back.
>> Doesn't Tkinter require TclTk to be installed? If so, is there an advantage
>> to having gui.tcl run under Python/Tkinter vs. Wish as it does now? That is,
>> the wxPython prototype I'm working on can launch a GRASS command and it's
>> TclTk gui. Of course this means I'm running part of the UI under TclTk and
>> part under wxPython at the moment. Does Tkinter change this?
>> Michael
>> phone: 480-965-6213
>> fax: 480-965-7671
>>> From: Cedric Shock <cedricgrass at shockfamily.net>
>>> Date: Sat, 15 Jul 2006 13:43:49 -0700
>>> To: <grass-dev at grass.itc.it>
>>> Subject: [GRASS-dev] Using current grass gui.tcl in python programs.
>>> Hi,
>>> This might be a quick way to get up and running with playing with python
>>> development. It's fairly easy to use the current gui.tcl in python. Here's
>>> an
>>> example (copy / paste into python run in grass). This could all be bundled
>>> up
>>> and abstracted away to be more useful. I also stuck this snippit on the wiki
>>> at http://grass.gdf-hannover.de/wiki/GRASS_and_Python , so if you make
>>> improvements please share them here and there.
>>> --Cedric
>>> import Tkinter
>>> import os
>>> # Startup (onde):
>>> tk = Tkinter.Tk()
>>> tk.eval ("wm withdraw .")
>>> tk.eval ("source $env(GISBASE)/etc/gui.tcl")
>>> # Here you could do various things to change what the gui does
>>> # See gui.tcl and README.GUI
>>> # Make a gui (per dialog)
>>> # This sets up a window for the command.
>>> # This can be different to integrate with tkinter:
>>> tk.eval ('set path ".dialog$dlg"')
>>> tk.eval ('toplevel .dialog$dlg')
>>> # Load the code for this command:
>>> fd = os.popen ("d.vect --tcltk")
>>> gui = fd.read()
>>> # Run it
>>> tk.eval(gui)
>>> dlg = tk.eval('set dlg') # This is used later to get and set
>>> # Get the current command in the gui we just made:
>>> currentcommand = tk.eval ("dialog_get_command " + dlg)
>>> # Set the command in the dialog we just made:
>>> tk.eval ("dialog_set_command " + dlg + " {d.vect map=roads}")
>> grass-dev mailing list
>> http://grass.itc.it/mailman/listinfo/grass-dev
> Jachym Cepicky
> e-mail: jachym.cepicky at centrum.cz
> URL: http://les-ejk.cz
> GPG: http://les-ejk.cz/gnupg_public_key/jachym_cepicky-gpg_public_key.asc
> OFFICE:
> GDF-Hannover
> Mengendamm 16d
> 30177 Hannover
> Germany
> e-mail: cepicky at gdf-hannover.de
> URL:    http://gdf-hannover.de
> Tel.:   +49 511-39088507
