[GRASS-dev] [bug #4867] (grass) DBF errors when chart and thematic
map displayed
Request Tracker
grass-bugs at intevation.de
Tue Jul 18 11:58:51 EDT 2006
this bug's URL: http://intevation.de/rt/webrt?serial_num=4867
Subject: DBF errors when chart and thematic map displayed
Platform: Mac OSX
grass obtained from: Other (CDROM etc)
grass binary for platform: Downloaded precompiled Binaries
Hello,
When you try and display both a vector chart (bar type only) and a vector thematic map, this seems to induce some kind of error in the gis.m. None of the fields in the DBF can be diplayed in the theme (nor even the vector shape of the theme). I tested both the bar chart and thematic layers independently and verified that they were both valid commands. I've posted my gis.m file below. Thanks for any resolve to this.
Cheers,
-Mike
chart chart for ethanol_plant_rfa_r1
_check 1
map ethanol_plant_rfa_r1
layer 1
ctype bar
columns cur_cap,plan_cap
sizecol
csize 10
cscale 0.08
ocolor black
fcolors green,yellow
type_point 1
type_line 1
type_boundary 1
type_centroid 1
type_area 0
End
Vector states_2002
_check 1
vect states_2002
display_shape 1
display_cat 0
display_topo 0
display_dir 0
display_attr 0
type_point 1
type_line 1
type_boundary 1
type_centroid 0
type_area 0
type_face 0
color #000000
_use_color 1
fcolor #AAAAAA
_use_fcolor 1
lcolor #000000
rdmcolor 0
sqlcolor 0
icon basic/x
size 5
lwidth 0
layer 1
lfield 1
attribute
xref left
yref center
lsize 8
cat
where
_use_where 1
qmap
qsave 0
qoverwrite 0
minreg
maxreg
End
thematic thematic map for ag_census_2002
_check 1
map ag_census_2002
type area
column M178_02
themetype graduated_colors
themecalc interval
breakpoints
where M178_02 > 0
layer 1
icon basic/circle
ptsize 5
maxsize 20
nint 6
colorscheme custom_gradient
pointcolor #FF0000
linecolor #000000
startcolor #ffffce
endcolor #e4bb00
border 1
update_rgb 1
math 0
psmap /tmp/foo
titlefont {times} 14 bold
tfontcolor #000000
subtitlefont {times} 12 bold
labelfont {times} 12
lfontcolor #000000
End
-------------------------------------------- Managed by Request Tracker
