[GRASS-dev] [bug #4865] (grass) v.proj, tcltk GUI: button for input vector map is wrong
Markus Neteler neteler at itc.it
Tue Jul 18 14:34:46 EDT 2006
On Tue, Jul 18, 2006 at 10:11:39AM -0700, Michael Barton wrote:
> As v.proj currently works, it will only reproject a vector within the
> current location. The TclTk georectifier gets around that issue.
Michael,
this is not right. v.proj works for other locations.
You probably refer to v.transform?
Maciek is right with his report.
Markus
> > From: Request Tracker <grass-bugs at intevation.de>
> > Reply-To: Request Tracker <grass-bugs at intevation.de>
> > Date: Tue, 18 Jul 2006 17:28:17 +0200 (CEST)
> > To: <grass-dev at grass.itc.it>
> > Subject: [GRASS-dev] [bug #4865] (grass) v.proj, tcltk GUI: button for input
> > vector map is wrong
> > this bug's URL: http://intevation.de/rt/webrt?serial_num=4865
> > Subject: v.proj, tcltk GUI: button for input vector map is wrong
> > Platform: GNU/Linux/x86
> > grass obtained from: CVS
> > grass binary for platform: Compiled from Sources
> > GRASS Version: 2006-07-10
> > If one presses the button for 'Name of the input vector map', a list of
> > vectors in the *current location* pops up. While the user is supposed to enter
> > the name of a vector from *another location* - the one he is reprojecting
> > from.
> > The button should be removed no to confuse the user.
> > Maciek
> > -------------------------------------------- Managed by Request Tracker
