[GRASS-dev] compile gdal plugin
Paolo Cavallini
cavallini at faunalia.it
Thu Jul 20 13:29:06 EDT 2006
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
I confirm, even after recompiling grassand using
configure --with-gdal=/usr/local/bin/gdal-config
--with-grass=/usr/local/grass-6.1.0beta1
I get the same error. Also, qgis does not load grass plugin:
ERROR 1: libgrass_I.so: cannot open shared object file: No such file or
directory
Thanks for your interest.
pc
Frank Warmerdam wrote:
>> Hash: SHA1
>> Hi all.
>> I recompiled today's grass-6.1beta1, then recompiled the gdal-grass
>> plugin with:
>> ./configure --with-grass=/usr/local/grass-6.1.0beta1
>> - --with-autoload=/usr/local/lib/gdalplugins --with-ld-shared="g++
>> -shared"
>> but I get this error:
>> checking for G_asprintf in -lgrass_gis... no
>> configure: error: --with-grass=/usr/local/grass-6.1.0beta1 requested,
>> but libraries not found!
> Paolo,
> I did:
> and it seemed to work fine on my machine.
> I think you will need to scan config.log to see what went wrong. If you
> want, you can forward it to me, and I'll take a look.
> Best regards,
Paolo Cavallini
email+jabber: cavallini at faunalia.it
www.faunalia.it
Piazza Garibaldi 5 - 56025 Pontedera (PI), Italy Tel: (+39)348-3801953
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.3 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFEv71i/NedwLUzIr4RAlfyAJ9b0zehpEvyaxl8qSc/h2a9opEosACfYGm/
KxAAUS/YIJeAK5/nocrrW4s=
=IALC
-----END PGP SIGNATURE-----
