[GRASS-dev] compile gdal plugin
Markus Neteler
neteler at itc.it
Thu Jul 20 13:38:27 EDT 2006
ciao Paolo,
as Frank wrote:
"you will need to scan config.log to see what went wrong"
no other way...
Markus
On Thu, Jul 20, 2006 at 07:29:06PM +0200, Paolo Cavallini wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> I confirm, even after recompiling grassand using
> configure --with-gdal=/usr/local/bin/gdal-config
> --with-grass=/usr/local/grass-6.1.0beta1
> I get the same error. Also, qgis does not load grass plugin:
> ERROR 1: libgrass_I.so: cannot open shared object file: No such file or
> directory
> Thanks for your interest.
> pc
> >> Hash: SHA1
> >> Hi all.
> >> I recompiled today's grass-6.1beta1, then recompiled the gdal-grass
> >> plugin with:
> >> ./configure --with-grass=/usr/local/grass-6.1.0beta1
> >> - --with-autoload=/usr/local/lib/gdalplugins --with-ld-shared="g++
> >> -shared"
> >> but I get this error:
> >> checking for G_asprintf in -lgrass_gis... no
> >> configure: error: --with-grass=/usr/local/grass-6.1.0beta1 requested,
> >> but libraries not found!
> > Paolo,
> > I did:
> > and it seemed to work fine on my machine.
> > I think you will need to scan config.log to see what went wrong. If you
> > want, you can forward it to me, and I'll take a look.
> > Best regards,
> Paolo Cavallini
> email+jabber: cavallini at faunalia.it
> www.faunalia.it
> Piazza Garibaldi 5 - 56025 Pontedera (PI), Italy Tel: (+39)348-3801953
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.3 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
> iD8DBQFEv71i/NedwLUzIr4RAlfyAJ9b0zehpEvyaxl8qSc/h2a9opEosACfYGm/
> KxAAUS/YIJeAK5/nocrrW4s=
> =IALC
> -----END PGP SIGNATURE-----
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
Markus Neteler <neteler itc it> http://mpa.itc.it/markus/
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
