[GRASS-dev] New OpenGL options to test for native Mac and Win NVIZ
William Kyngesburye
woklist at kyngchaos.com
Fri Jul 21 22:30:31 EDT 2006
Well, for now I have my GRASS installer build the fonts at install-
time. This should assure that they are the correct endian for PPC/
Intel Macs.
I also fixed the PROJ datum grid files to do the same, in my GIS Libs
package. The GRASS etc/nad is then symlinked to the PROJ data folder
to simplify installation and maintenance of the datum files. (I hope
this works and doesn't cause problems)
On Jul 20, 2006, at 10:18 AM, Paul Kelly wrote:
> On Thu, 20 Jul 2006, William Kyngesburye wrote:
>> On Jul 20, 2006, at 2:03 AM, Glynn Clements wrote:
>>> There is a similar issue with the datum shift grids used by PROJ.
>> Oh damn! I'm surprised noone has said anything from using my
>> universal binaries (built on Intel Mac). Maybe the datum grids
>> are just not used much (it's only the extras for the states). And
>> here I was working on frameworks for my installers. The PROJ
>> framework would have the same problem as with the GRASS fonts, but
>> I'm not sure I can do run-time processing in this case.
> Is there any particular reason why installable Mac binaries
> couldn't run an install script? It would seem like a pretty common
> thing to want to do :/
> Paul
William Kyngesburye <kyngchaos at kyngchaos.com>
http://www.kyngchaos.com/
"History is an illusion caused by the passage of time, and time is an
illusion caused by the passage of history."
- Hitchhiker's Guide to the Galaxy
