[GRASS-dev] [bug #4886] (grass) setting position of windows
Hamish
hamish_nospam at yahoo.com
Sat Jul 22 22:20:11 EDT 2006
> this bug's URL: http://intevation.de/rt/webrt?serial_num=4886
> Subject: setting position of windows
> Platform: GNU/Linux/x86
> grass obtained from: Trento Italy site
> grass binary for platform: Compiled from Sources
> GRASS Version: cvs_2006_07_22
> hi!
> with the new gis.m loading all those windows (I do like it!), I was
> wandering if it is possible to set somewhere where they must be
> opened. For example, console in lower left corner, map display on the
> upper right corner, and so on. Or may be it is already possible and I
> don't know where to look...
> Thanks!
While this is possible to do with TclTk, and in the past we did place
some of the windows, it was reverted to unplaced so that GRASS wasn't
over-ruling local window manager settings. Personally I don't like
having 4-6 windows open for a grass session, I think it is messy.
What I've done: (sawfish WM + gnome)
sawfish-ui # config program
matched windows tab
^v\.digit - position=(300 . 875) # middle bottom
^xterm$ position=(35 . 605) # bottom left
GIS Manager - position=(750 . 10) # top right
^Map Display 1$ place-mode=top-left
^Output - GIS\.m$ place-mode=south-east-going-north
I suspect that these would override hardcoded placement in gis.m, but
I'm not sure. But that may depend on WM.
Hamish
