[GRASS-dev] wierd results with r.series meth=perc90,q3
Sat Jul 22 23:58:02 EDT 2006
I'm getting some strange results with r.series method=perc90 and quart3.
8 input maps, partially overlapping, each map has nodata areas of NULL.
(CELL maps, 0->254 + NULL)
the perc90 results in a blank map (r.info: min=nan, max=nan) while the
quart3 map only seems to have data in slivers where some of the layers
overlap.
also, it would be nice if for stats like min,max, if only CELL maps are
given for input, a CELL map will be written as output. Probably the
sanest way to do this is to add an outtype=CELL option to the module?
(e.g. r.in.xyz)  I guess we should use rounding in the case of a CELL
map?
thanks,
Hamish
