[GRASS-dev] [bug #4898] (grass) g.proj -p segfaults because of missing datum name
Request Tracker grass-bugs at intevation.de
Mon Jul 24 09:21:19 EDT 2006
this bug's URL: http://intevation.de/rt/webrt?serial_num=4898
Subject: g.proj -p segfaults because of missing datum name
Platform: GNU/Linux/x86
grass obtained from: CVS
grass binary for platform: Compiled from Sources
GRASS Version: cvs_head_20060724
Trying to use the "Use georeferenced file" for new location definition in the start-up screen I get a segfault.
Searching for the cause, I find that it's in the call to g.proj, as calling g.proj -p on the file gives the following:
> g.proj -p UrbAdm_Mu.shp
Trying to open with GDAL...ERROR 4: `UrbAdm_Mu.shp' not recognised as a supported file format.
Trying to open with OGR......succeeded.
WARNING: Datum 'unnamed' not recognised by GRASS and no parameters found.
         Datum transformation will not be possible using this projection
         information.
Segmentation fault
The warning comes from GPJ_osr_to_grass() which is in lib/proj/convert.c. I don't know why it segfaults, though.
Do we absolutely need a datum name as the information contained in the .prj file seems to be sufficient to create a location ?
ogrinfo gives the following on the file:
$ ogrinfo -so UrbAdm_Mu.shp UrbAdm_Mu
INFO: Open of `UrbAdm_Mu.shp'
using driver `ESRI Shapefile' successful.
Layer name: UrbAdm_Mu
Geometry: Polygon
Feature Count: 19
Extent: (141192.712000, 161464.403000) - (158005.472000, 178169.335000)
Layer SRS WKT:
PROJCS["Belge 1972 / Belgian Lambert 72",
    GEOGCS["unnamed",
        DATUM["unnamed",
            SPHEROID["International_1924",6378388,297.0000000000601]],
        PRIMEM["Greenwich",0],
        UNIT["Degree",0.017453292519943295]],
    PROJECTION["Lambert_Conformal_Conic_2SP"],
    PARAMETER["standard_parallel_1",51.16666723333333],
    PARAMETER["standard_parallel_2",49.8333339],
    PARAMETER["latitude_of_origin",90],
    PARAMETER["central_meridian",4.367486666666666],
    PARAMETER["false_easting",150000.013],
    PARAMETER["false_northing",5400088.438],
    UNIT["Meter",1]]
MUID: Real (20.0)
POLID: Real (20.0)
REID: Real (20.0)
MUNC: String (5.0)
MU3C: String (3.0)
MUDN: String (24.0)
MUDNIN: String (2.0)
MUFN: String (24.0)
MUFNIN: String (2.0)
Moritz
-------------------------------------------- Managed by Request Tracker
