[GRASS-dev] [bug #4519] (grass) errors in Grass 55 build
Maciek Sieczka via RT
grass-bugs at intevation.de
Mon Jul 24 10:40:04 EDT 2006
paul-grass at stjohnspoint.co.uk wrote (Mon, Jul 24 2006 10:32:58):
> Ah you must be using the new "alternative" build system then - Hamish's
> instructions were for the old system. You need to find the script gmake55
> which will be in the root of your build directory (this directory should
> be outside of the source tree structure) and run it from there as follows:
> ./gmake55 src/imagery/i.cca
This method failed too. Finally I found gmake55 executable in
bin.i686-pc-linux-gnu dir, copied it to a dir included in my PATH and it
works. Details:
$ gmake55 src/imagery/i.cca/
SRC = /home/shoofi/src/straight/grass/src
CMD = /home/shoofi/src/straight/grass/src/CMD
UNUSED = /home/shoofi/src/straight/grass/unused
HEADER = head.i686-pc-linux-gnu
ARCH = i686-pc-linux-gnu
GISBASE = /home/shoofi/src/straight/grass/dist.i686-pc-linux-gnu
VERSION = 5.5-cvs 2004
/home/shoofi/src/straight/grass/src/imagery/i.cca
make -f OBJ.i686-pc-linux-gnu/make.rules
/home/shoofi/bin/gmake55 -all
/home/shoofi/src/straight/grass/src/imagery/i.cca/cmd
make[1]: Entering directory
`/home/shoofi/src/straight/grass/src/imagery/i.cca/cmd'
gcc -I/home/shoofi/src/straight/grass/src/include -g -O2 -c matrix.c -o
OBJ.i686-pc-linux-gnu/matrix.o
In file included from matrix.c:3:
globals.h:12: error: array type has incomplete element type
make[1]: *** [OBJ.i686-pc-linux-gnu/matrix.o] Error 1
make[1]: Leaving directory `/home/shoofi/src/straight/grass/src/imagery/i.cca/cmd'
make: *** [all] Error 1
$ gmake55 src/raster/r.grow2
/home/shoofi/src/straight/grass/src/raster/r.grow2
gcc -I/home/shoofi/src/straight/grass/src/include -g -O2 -c main.c -o
OBJ.i686-pc-linux-gnu/main.o
main.c:13: error: static declaration of 'abs' follows non-static declaration
make: *** [OBJ.i686-pc-linux-gnu/main.o] Error 1
$ gmake55 src/sites/s.in.ascii
/home/shoofi/src/straight/grass/src/sites/s.in.ascii
main.c: In function 'G_site_put_new':
main.c:184: error: invalid storage class for function 'format_double'
$ gmake55 src.contrib/SDTS
/home/shoofi/src/straight/grass/src.contrib/SDTS
/home/shoofi/bin/gmake55 ./libes/fips123
/home/shoofi/src/straight/grass/src.contrib/SDTS/libes/fips123
`/home/shoofi/src/straight/grass/src.contrib/SDTS/libes/fips123'
make[1]: Nothing to be done for `all'.
/home/shoofi/bin/gmake55 ./mapdev/v.out.sdts
/home/shoofi/src/straight/grass/src.contrib/SDTS/mapdev/v.out.sdts
`/home/shoofi/src/straight/grass/src.contrib/SDTS/mapdev/v.out.sdts'
-I../../libes/fips123/f123inc -g -O2 -c v.out.sdts.c -o
OBJ.i686-pc-linux-gnu/v.out.sdts.o
In file included from v.out.sdts.c:29:
externs.h:29: error: array type has incomplete element type
externs.h:30: error: array type has incomplete element type
externs.h:31: error: array type has incomplete element type
externs.h:32: error: array type has incomplete element type
externs.h:33: error: array type has incomplete element type
make[1]: *** [OBJ.i686-pc-linux-gnu/v.out.sdts.o] Error 1
make: *** [all] Error 2
$ gmake55 src.garden/grass.postgresql
/home/shoofi/src/straight/grass/src.garden/grass.postgresql
/home/shoofi/bin/gmake55 d.rast.pg
/home/shoofi/src/straight/grass/src.garden/grass.postgresql/d.rast.pg
`/home/shoofi/src/straight/grass/src.garden/grass.postgresql/d.rast.pg'
make[1]:
`/home/shoofi/src/straight/grass/dist.i686-pc-linux-gnu/etc/bin/cmd/d.rast.pg'
is up to date.
/home/shoofi/bin/gmake55 d.site.pg
/home/shoofi/src/straight/grass/src.garden/grass.postgresql/d.site.pg
`/home/shoofi/src/straight/grass/src.garden/grass.postgresql/d.site.pg'
make[1]:
`/home/shoofi/src/straight/grass/dist.i686-pc-linux-gnu/etc/bin/cmd/d.site.pg'
is up to date.
/home/shoofi/bin/gmake55 d.vect.pg
/home/shoofi/src/straight/grass/src.garden/grass.postgresql/d.vect.pg
`/home/shoofi/src/straight/grass/src.garden/grass.postgresql/d.vect.pg'
make[1]:
`/home/shoofi/src/straight/grass/dist.i686-pc-linux-gnu/etc/bin/cmd/d.vect.pg'
is up to date.
/home/shoofi/bin/gmake55 d.what.s.pg
/home/shoofi/src/straight/grass/src.garden/grass.postgresql/d.what.s.pg
`/home/shoofi/src/straight/grass/src.garden/grass.postgresql/d.what.s.pg'
gcc -I/home/shoofi/src/straight/grass/src/include -I/usr/include/postgresql/
-Wall -DPACKAGE=\""d.what.s.pg"\" -g -O2 -c runPg.c -o
OBJ.i686-pc-linux-gnu/runPg.o
runPg.c: In function 'runPg':
runPg.c:122: error: invalid lvalue in assignment
make[1]: *** [OBJ.i686-pc-linux-gnu/runPg.o] Error 1
$ gmake55 src.contrib/DUKE/r.terraflow
/home/shoofi/src/straight/grass/src.contrib/DUKE/r.terraflow
/home/shoofi/bin/gmake55 IOStream/lib
/home/shoofi/src/straight/grass/src.contrib/DUKE/r.terraflow/IOStream/lib
`/home/shoofi/src/straight/grass/src.contrib/DUKE/r.terraflow/IOStream/lib'
c++ -I/home/shoofi/src/straight/grass/src/include -I../include -g -O2 -c
minmaxheap_test.cc -o OBJ.i686-pc-linux-gnu/minmaxheap_test.o
../include/replacementHeap.h:155: error: invalid use of constructor as a template
../include/replacementHeap.h:155: note: use 'ReplacementHeap<T,
Compare>::ReplacementHeap' instead of 'ReplacementHeap<T, Compare>::class
ReplacementHeap<T, Compare>' to name the constructor in a qualified name
../include/replacementHeapBlock.h:161: error: invalid use of constructor as a
template
../include/replacementHeapBlock.h:161: note: use 'ReplacementHeapBlock<T,
Compare>::ReplacementHeapBlock' instead of 'ReplacementHeapBlock<T,
Compare>::class ReplacementHeapBlock<T, Compare>' to name the constructor in a
qualified name
make[1]: *** [OBJ.i686-pc-linux-gnu/minmaxheap_test.o] Error 1
make: *** [IOStream/lib/LIB.i686-pc-linux-gnu/libiostream.a] Error 2
Maciek
-------------------------------------------- Managed by Request Tracker
