[GRASS-dev] [bug #4519] (grass) errors in Grass 55 build
Maciek Sieczka via RT
grass-bugs at intevation.de
Mon Jul 24 12:10:51 EDT 2006
pkelly wrote (Mon, Jul 24 2006 17:06:35):
> OK I think I have fixed those in the 5.5 CVS HEAD (apart from the C++ errors
> in r.terraflow which I don't have a clue about).
Allright, mostly OK. Only src.contrib/SDTS still fails (and the r.terraflow,
but since you can't help it let's leave this aside for a moment):
$ gmake55 src.contrib/SDTS
SRC = /home/shoofi/src/straight/grass/src
CMD = /home/shoofi/src/straight/grass/src/CMD
UNUSED = /home/shoofi/src/straight/grass/unused
HEADER = head.i686-pc-linux-gnu
ARCH = i686-pc-linux-gnu
GISBASE = /home/shoofi/src/straight/grass/dist.i686-pc-linux-gnu
VERSION = 5.5-cvs 2004
/home/shoofi/src/straight/grass/src.contrib/SDTS
make -f OBJ.i686-pc-linux-gnu/make.rules
/home/shoofi/bin/gmake55 ./libes/fips123
/home/shoofi/src/straight/grass/src.contrib/SDTS/libes/fips123
make[1]: Entering directory
`/home/shoofi/src/straight/grass/src.contrib/SDTS/libes/fips123'
make[1]: Nothing to be done for `all'.
make[1]: Leaving directory
/home/shoofi/bin/gmake55 ./mapdev/v.out.sdts
/home/shoofi/src/straight/grass/src.contrib/SDTS/mapdev/v.out.sdts
`/home/shoofi/src/straight/grass/src.contrib/SDTS/mapdev/v.out.sdts'
gcc -I/home/shoofi/src/straight/grass/src/include
-I../../libes/fips123/f123inc -g -O2 -c v.out.sdts.c -o
OBJ.i686-pc-linux-gnu/v.out.sdts.o
In file included from v.out.sdts.c:30:
globals.h:30: error: conflicting types for 'Ddr_elem'
externs.h:30: error: previous declaration of 'Ddr_elem' was here
globals.h:62: error: conflicting types for 'Mod'
externs.h:29: error: previous declaration of 'Mod' was here
make[1]: *** [OBJ.i686-pc-linux-gnu/v.out.sdts.o] Error 1
make: *** [all] Error 2
> But the modules compiled OK for me so I think the problem might be that your
> compiler settings are too strict. Some of the GRASS code is very old and
> conforms to Kernighan & Ritchie style instead of ANSI C. That may or may not
> be considered a bug but you should be able to configure your compiler to
> accept it.
I'm not using any custom compiler/linker options. I'm relying on a default,
just doing:
./configure --with-cxx --without-odbc
--with-tcltk-includes="/usr/include/tcl8.4/"
--with-postgres-includes="/usr/include/postgresql/" --with-freetype
--with-freetype-includes="/usr/include/freetype2/" --with-readline
then make
Maybe the issue is my GCC version - 4.0.3?
Maciek
-------------------------------------------- Managed by Request Tracker
