[GRASS-dev] [bug #4604] (grass) tcl/tk GUI: v.digit can't create new vector in GUI mode
Michael Barton michael.barton at asu.edu
Tue Jul 25 01:39:12 EDT 2006
I'm at home on my laptop. However, I just updated all gism files from the
cvs.
I had no problem editing an existing vector from the GUI before or after
updating.
Before updating all gism files, I could NOT create a new vector to digitize
by doing the following: 1) add a vector layer, 2) type a new name (i.e.,
vector name that does not currently exist) into the vector name entry field,
3) press the digitize button.
After updating, I COULD create a new vector to digitize by doing the steps
listed above. As of Friday, I completed a set of changes to the way that
TclTk parses GRASS commands, in line with Glynn's suggestions. This made
several things begin to work again on my Mac that had been behaving
strangely. Maybe it fixed the v.digit issue.
The TclTk code for creating a new vector is as Glynn indicates below
(v.digit -n map=[new map name]).
One complicating issue is that a couple months ago, Lorenzo Moretti began to
include a version of v.digit, specifically for the Mac, that fixed some of
the problems of the last several months. However, this only worked in TclTk
aqua. I don't know if this is in the binary version I'm running on my laptop
here at home (10 June 2006). However, I'm running gism in x11
mode--including v.digit (i.e., it does NOT open in TclTk aqua)--and v.digit
works OK.
So it works for me currently. Maybe it now works for you all too (as of
Friday). Update to the most recent versions of all TclTk interface files and
see. If it doesn't work for you all after this, there is still hope. I can
confirm that there IS a version that does work and it works on TclTk for x11
as well as aqua. I'm using it currently. This version needs to be submitted
to the GRASS cvs for testing. I'm copying Lorenzo to see if he has anything
to add to this, since I'm using his 6 June binary with my TclTk code
updates.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Glynn Clements <glynn at gclements.plus.com>
> Date: Mon, 24 Jul 2006 17:54:19 +0100
> To: Maciek Sieczka via RT <grass-bugs at intevation.de>
> Cc: <epatton at nrcan.gc.ca>, <grass-dev at grass.itc.it>
> Subject: Re: [GRASS-dev] [bug #4604] (grass) tcl/tk GUI: v.digit can't create
> Maciek Sieczka via RT wrote:
>>> So this is NOT a bug. It is the way that the GRASS CLI is supposed to work.
>>> You can make it a wish, however.
>> Michael,
>> You are right that it is not a bug, that v.digit from CLI doesn't spawn a
>> monitor automatically. It shouldn't do that and this is clear.
>> However, there *is* a bug v.digit in tcl/tk GUI mode that prevents it from
>> creating a new vector. Try to reproduce it, like this:
>> $ d.mon x0
>> $ v.digit&
>> Now type in the new vector name and check the "Create new file..." button (so
>> that the whole command is eg. "v.digit map=new_vector -n"), press Run
>> The output is:
>> GRASS_INFO_MESSAGE(17052,1): New empty map created.
>> Application initialization failed: "-n" option requires an additional
>> argument
>> Error in startup script: couldn't read file "map=new_vector": no such file or
>> directory
> Those error messages come from Tk; it's because v.digit is passing its
> command-line options to Tk, which is trying to interpret them.
> Note:
> $ wish map=new_vector -n
> Application initialization failed: "-n" option requires an additional argument
> directory
> v.digit needs to pass a "fake" command-line to Tk_Main().
>> As Markus said, this works from CLI fine so this might be a GUI specific
>> issue. Can you look into this?
> That exact case shouldn't work from the command line either. However,
> putting the -n first will eliminate the error message, as it will have
> the argument which it requires (Tk treats -n as a shorthand for
> -name).
