[GRASS-dev] gis.m fails to start
Morten Hulden
morten at untamo.net
Thu Jul 27 12:56:54 EDT 2006
is this a bug that only shows up on my distro (Fedora 5). Why would
mysql client libs be needed even when I compile without mysql support?
cvs version 20060727
GRASS 6.1.cvs (map18):~ > gis.m &
GRASS 6.1.cvs (map18):~ > Error in startup script: g.region: error while
loading shared libraries: libmysqlclient.so.14: cannot open shared
object file: No such file or directory
while executing
"close $input"
(procedure "MapCanvas::zoom_gregion" line 13)
invoked from within
"MapCanvas::zoom_gregion $mon"
(procedure "MapCanvas::create" line 46)
invoked from within
"MapCanvas::create"
(procedure "Gm::startmon" line 11)
invoked from within
"Gm::startmon"
(procedure "Gm::create" line 74)
invoked from within
"Gm::create"
(procedure "main" line 30)
invoked from within
"main $argc $argv"
(file "/usr/local/grass-6.1.cvs/etc/gm/gm.tcl" line 528)
