[GRASS-dev] gis.m: cannot get profile from profile tool
Michael Barton michael.barton at asu.edu
Fri Jul 28 14:47:58 EDT 2006
Moritz,
I found the problem and fixed the profiler so that it works in latlon
regions now. I just committed it to the cvs.
I'd like to improve it a bit so that it scales the vertical axis according
to height values visible in the display rather than according to the entire
map. r.describe seemed like just the module to do this, but I found that its
output format varies according to whether 1) the map is a latlon or
non-latlon region, 2) if all the values are positive or negative, or 3) some
of the raster values are negative and some are positive. This makes it
impossible to parse easily and use in a GUI script like profile.tcl
IMHO, it should output its results in the same format regardless of the map
characteristics.
Here is what it does:
1) r.describe format for latlon
 r.describe map=srtm -1rqd
387.000000-831.000000
 r.describe map=srtm rqd
2) r.describe format for non latlon with all positive or all negative values
 r.describe -1rqd map=elevation_dem
1066
1840
 r.describe -rqd map=elevation_dem
1066 thru 1840
 r.describe -1rqd map=elevation_neg
-1840
-1066
-1840 thru -1066
3) r.describe format for non latlon with some positive and some negative
values
 r.describe -rqd map=elevation_neg2
-640 thru -1
0
1 thru 134
 r.describe -1rqd map=elevation_neg2
-640
-1
0
1
134
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Moritz Lennert <mlennert at club.worldonline.be>
> Date: Thu, 27 Jul 2006 14:40:41 +0200
> To: Michael Barton <michael.barton at asu.edu>
> Cc: Grass Developers List <grass-dev at grass.itc.it>
> Subject: Re: [GRASS-dev] gis.m: cannot get profile from profile tool
> Micheal,
> I think I found it: It seems that the tcltk profiling tool does not work
> in a latlong projections.
> I just reprojected the map into a projected location and now it works !
> So, if this is confirmed, we will either have to add a warning or find a
> way to use latlong projections.
> Moritz
> Michael Barton wrote:
>> Try this update to profile.tcl. Just drop it into $GISBASE/etc/gm
>> I found a way to set the max and min elevation according to the region
>> displayed. This makes more sense. Maybe it will fix your problem too.
>> Michael
>> Center for Social Dynamics & Complexity
>> phone: 480-965-6213
>> fax: 480-965-7671
>>> Date: Thu, 27 Jul 2006 08:33:11 +0200
>>>> Hi Moritz,
>>>> Did you select a raster to profile?
>>> Yes, as you can see in the screenshot, it says in the bottom left:
>>> "Profile for srtm_be".
>>>> Third button from the left on the
>>>> profiler toolbar.
>>>> Rather like d.profile, the profiler differentiates between
>>>> a map you use as a background to the profiling line (what is shown in the
>>>> map display) and the map that you actually use to compute profile values.
>>> I understand that, but I still don't get a profile. Actually, I
>>> sometimes do not even get the straight blue line you see in the
>>> screenshot (http://moritz.homelinux.org/grass/gism_profile.png), just an
>>> empty graph.
>>> The min and max of the heights on the y axis seem correct, though.
>>> Moritz
>> # profile.tcl - Dialog to create profile of raster surface for GRASS GIS
>> Manager
>> # May 2006 Michael Barton, Arizona State University
>> # COPYRIGHT: (C) 1999 - 2006 by the GRASS Development Team
>> #  This program is free software under the GNU General Public
>> #  License (>=v2). Read the file COPYING that comes with GRASS
>> #  for details.
>> namespace eval GmProfile {
>> variable pcan
>> variable status ""
>>     variable pmap ""
>>     variable pmainframe
>> variable transect ""
>> variable tottransect ""
>> variable pcoords ""
>> variable pcoordslist ""
>> variable profilelist ""
>> variable x
>> variable y
>> variable first 1
>>     variable firsteast 0.0
>>     variable firstnorth 0.0
>>     variable east1 0.0
>>     variable north1 0.0
>>     variable east2 0.0
>>     variable north2 0.0
>> variable tlength 0.0
>> variable tottlength 0.0
>>     variable linex1 0.0
>>     variable liney1 0.0
>>     variable linex2 0.0
>>     variable liney2 0.0
>>     variable array psegment len #
>>     variable elevrange 0.0
>>     variable elevmax 0.0
>>     variable elevmin 0.0
>>     variable elev 0.0
>> # select raster map to profile
>> # select base raster map from list and put name in layer tree node
>> proc GmProfile::select_rast { } {
>> variable pmap
>> variable status
>> variable elevrange
>> variable elevmax
>> variable elevmin
>>     set m [GSelect cell]
>>     if { $m != "" } {
>>         set pmap $m
>>     #calculate elevation range so all profiles with same window geometry with
>> have
>>     # same scale. Scale depends on region.
>> set input [exec r.describe -rdq map=$pmap]
>> regexp -nocase {^([0-9]+) thru ([0-9]+)} $input trash elevmin elevmax
>> set elevrange [expr $elevmax - $elevmin]
>> # put map name in status bar
>>     set GmProfile::status [G_msg "Profile for $pmap"]
>> # create canvas for displaying profile
>> proc GmProfile::create { mapcan } {
>> global gmpath
>> global iconpath
>>     global env
>>     global bgcolor
>> variable pmap
>> variable pcan
>> if { [winfo exists .profile] } {return}
>> set ptitle "Profile Window"
>> toplevel .profile
>>     wm title .profile [G_msg $ptitle]
>>     wm withdraw .profile
>>     #wm overrideredirect $txt 1
>> # create canvas for profile
>> set profilemf [MainFrame .profile.mf \
>> -textvariable GmProfile::status]
>> set profile_frame [$profilemf getframe]
>> set pcan [canvas $profile_frame.can -bg white\
>> -borderwidth 0 -closeenough 1.0 \
>>         -relief ridge -selectbackground #c4c4c4 \
>>         -width 600 -height 200 ]
>>     # setting geometry
>>     place $pcan \
>>         -in $profile_frame -x 0 -y 0 -anchor nw \
>>         -bordermode ignore
>> # profile control buttons
>> set pcan_tb [$profilemf addtoolbar]
>> set pcanbb [ButtonBox $pcan_tb.bb -orient horizontal]
>> $pcanbb add  -image [image create photo -file
>> "$iconpath/gui-profiledefine.gif"] \
>> -command "GmProfile::profilebind $mapcan" \
>>         -highlightthickness 0 -takefocus 0 -relief link -borderwidth 1  \
>>         -highlightbackground $bgcolor  -activebackground $bgcolor\
>>         -helptext [G_msg "Draw profile transect in map display"]
>> $pcanbb add -image [image create photo -file "$iconpath/gui-profiledraw.gif"]
>> -command "GmProfile::pdraw" \
>>         -helptext [G_msg "Draw profile"] -highlightbackground $bgcolor
>> $pcanbb add -image [image create photo -file "$iconpath/element-cell.gif"] \
>> -command "GmProfile::select_rast" \
>>         -helptext [G_msg "Select raster map to profile"] -highlightbackground
>> $bgcolor
>> $pcanbb add -image [image create photo -file "$iconpath/gui-erase.gif"] \
>> -command "GmProfile::perase $mapcan" \
>>         -helptext [G_msg "Clear profile"] -highlightbackground $bgcolor
>> $pcanbb add -image [image create photo -file "$iconpath/file-save.gif"] \
>> -command "GmProfile::psave" \
>>         -helptext [G_msg "Save profile to EPS file"] -highlightbackground
>> $bgcolor
>>     # add a menu button to set preferences?
>> pack $profilemf -expand yes -fill both -padx 0 -pady 0
>> pack $pcan -fill both -expand yes
>> pack $pcanbb -side left -anchor w
>>     $profilemf showstatusbar status
>>     pack $profilemf -fill both -expand yes
>> BWidget::place .profile 0 0 at 500 100
>>     wm deiconify .profile
>> # bindings for closing profile window
>> bind .profile <Destroy> "GmProfile::cleanup %W $mapcan"
>> # save profile to eps file
>> proc GmProfile::psave { } {
>> variable pcan
>> global env
>> set types {
>>     {{EPS} {.eps}}
>> if { [info exists HOME] } {
>> set dir $env(HOME)
>> set path [tk_getSaveFile -filetypes $types -initialdir $dir \
>> -defaultextension ".eps"]
>> } else {
>> set path [tk_getSaveFile -filetypes $types -defaultextension ".eps"]
>> $pcan postscript -file "$path"
>> return
>> # procedures for marking profile location
>> #  bindings for drawing profile transect
>> proc GmProfile::profilebind { mapcan } {
>> variable measurement_annotation_handle
>> variable tlength
>> variable tottlength
>>     variable linex1
>>     variable liney1
>>     variable linex2
>>     variable liney2
>>     variable first
>>     global mon
>> global GmProfile::msg
>> # Make the output for the measurement
>> set measurement_annotation_handle [monitor_annotation_start $mon
>> "Measurement" {}]
>> if {[info exists linex1]} {unset linex1}
>> if {[info exists liney1]} {unset liney1}
>> if {[info exists linex2]} {unset linex2}
>> if {[info exists liney2]} {unset liney2}
>> bind $mapcan <1> "GmProfile::marktransect $mapcan %x %y"
>> bind $mapcan <B1-Motion> "GmProfile::drawtransect $mapcan %x %y"
>> bind $mapcan <ButtonRelease-1> "GmProfile::getcoords $mapcan"
>>     set GmProfile::msg "Draw profile transect with mouse"
>> MapCanvas::setcursor $mon "pencil"
>> set tlength 0
>> set tottlength 0
>> # start profile transect
>> proc GmProfile::marktransect {mapcan x y} {
>> variable transect
>> variable tlength
>> variable tottlength
>>     variable linex1
>>     variable liney1
>>     variable linex2
>>     variable liney2
>>     variable first
>>     variable firsteast
>>     variable firstnorth
>>     variable pcoords
>>     #start line
>>     if { ![info exists linex1] } {
>> set linex1 [$mapcan canvasx $x]
>> set liney1 [$mapcan canvasy $y]
>> if { $first == 1 } {
>> set firsteast  [MapCanvas::scrx2mape $linex1]
>> set firstnorth [MapCanvas::scry2mapn $liney1]
>> set pcoords "$firsteast,$firstnorth"
>> set first 0
>> #check for click with no drag
>>     if { ![info exists linex2] } {
>> set linex2 $linex1
>>     if { ![info exists liney2] } {
>> set liney2 $liney1
>>     $mapcan delete transect
>> # draw profile transect
>> proc GmProfile::drawtransect { mapcan x y } {
>> variable transect
>> variable tlength
>> variable tottlength
>>     variable linex1
>>     variable liney1
>>     variable linex2
>>     variable liney2
>>     variable pcoords
>> set scrxmov $x
>> set scrymov $y
>> set eastcoord [eval MapCanvas::scrx2mape $x]
>> set northcoord [eval MapCanvas::scry2mapn $y]
>> set coords "$eastcoord,$northcoord"
>> set xc [$mapcan canvasx $x]
>> set yc [$mapcan canvasy $y]
>> # draw line segment
>> if {($linex1 != $xc) && ($liney1 != $yc)} {
>> $mapcan addtag transect withtag \
>> [$mapcan create line $linex1 $liney1 $xc $yc \
>> -fill red -arrow last -width 2]
>> set linex2 $xc
>> set liney2 $yc
>> # get coordinates for transect nodes and endpoints
>> proc GmProfile::getcoords { mapcan } {
>> variable transect
>> variable tlength
>> variable tottlength
>>     variable linex1
>>     variable liney1
>>     variable linex2
>>     variable liney2
>>     variable pcoords
>>     variable firsteast
>>     variable east1
>>     variable north1
>>     variable east2
>>     variable north2
>>     variable pcoords
>> # draw cumulative line
>> $mapcan addtag tottransect withtag \
>> [$mapcan create line $linex1 $liney1 $linex2 $liney2 \
>> -fill blue -arrow last -width 2]
>> # get line endpoints in map coordinates
>> set east1  [MapCanvas::scrx2mape $linex1]
>> set north1 [MapCanvas::scry2mapn $liney1]
>> set east2  [MapCanvas::scrx2mape $linex2]
>> set north2 [MapCanvas::scry2mapn $liney2]
>> # coordinates for use in r.profile
>> append pcoords "," $east2 "," $north2
>> # x distance off each transect segment
>> # First convert map coordinates to profile screen coordinates
>> # Then add the profile screen coordinates to the profile coordinates list.
>> # Only add east1 and north1 the first time;
>> # continue to add east2 and north2 until ready to draw profile
>> # calculate line segment length and total length
>> set tlength [expr {sqrt(pow(($east1 - $east2), 2) + pow(($north1 - $north2),
>> 2))}]
>> set tottlength [expr {$tottlength + $tlength}]
>> lappend pcoordslist $tottlength
>> monitor_annotate $measurement_annotation_handle " --segment length\t=
>> $tlength\n"
>> monitor_annotate $measurement_annotation_handle "cumulative length\t=
>> $tottlength\n"
>> set linex1 $linex2
>> set liney1 $liney2
>> # draw profile
>> proc GmProfile::pdraw {} {
>> variable pcan
>> variable pmap
>> variable tottlength
>> variable elevrange
>> variable elevmax
>> variable elevmin
>>     variable firsteast
>>     variable firstnorth
>>     variable east1
>>     variable north1
>>     variable east2
>>     variable north2
>>     variable pcoords
>> $pcan delete all
>> set profilelist ""
>> # calculate screen length and width
>> set w [winfo width $pcan]
>> set h [winfo height $pcan]
>> #calculate graph box and scale extents
>> set top [expr 0.10 * $h]
>> set bottom [expr 0.80 * $h]
>> set height [expr $bottom - $top]
>> set left [expr 0.2 * $w]
>> set right [expr 0.9 * $w]
>> set width [expr $right - $left]
>> set yscaleright [expr $left - 10]
>> set xscaletop [expr $bottom + 10]
>> # create y axis (from 20%x10% to 20%x80% - top to bottom)
>> $pcan create line $left $top $left [expr $bottom + 5]
>> # add scale to y axis
>> $pcan create text $yscaleright $top \
>> -text $elevmax \
>> -anchor e \
>> -justify right
>> $pcan create text $yscaleright $bottom \
>> -text $elevmin \
>> -anchor e \
>> -justify right
>> # create x axis (from 20%x80% to 90%x80% - left to right)
>> $pcan create line [expr $left - 5] $bottom $right $bottom
>> # add scale to x axis
>> $pcan create text $left $xscaletop \
>> -text "0" \
>> -anchor n \
>> -justify center
>> $pcan create text $right $xscaletop \
>> -text "$tottlength" \
>> -anchor n \
>> -justify center
>> # add tick marks
>> $pcan create line $right $bottom $right [expr $bottom + 5]
>> $pcan create line [expr $left - 5] $top $left $top
>> # add transect segment markers
>> foreach {x} $pcoordslist {
>> set segx [expr $left + (($x * $width) / $tottlength)]
>> $pcan create line $segx $bottom $segx $top -fill grey
>> # run r.profile
>> # convert dist elev (stdout) to xy coordinates of profile line
>> if {![catch {open "|r.profile input=$pmap profile=$pcoords" r} input]} {
>> while {[gets $input line] >= 0} {
>> if { [regexp -nocase {^([0-9].*) ([0-9].*)$} $line trash dist elev] } {
>> set pelev [expr $bottom - ($height * ($elev - $elevmin) / $elevrange)]
>> set pdist [expr $left + (($dist * $width) / $tottlength)]
>> lappend profilelist $pdist $pelev
>> catch close $input
>> # draw profile line
>> if { [llength $profilelist] > 3 } {
>> $pcan create line $profilelist -fill blue
>> # erase profile and clear transects
>> proc GmProfile::perase { mapcan } {
>> variable pcan
>> variable pmap
>> variable transect
>> variable tlength
>> variable tottlength
>> variable pcoords
>> variable first
>> variable linex1
>> variable liney1
>> variable elevrange
>> variable elevmax
>> variable elevmin
>> $pcan delete all
>> $mapcan delete tottransect
>> set tlength 0.0
>> set tottlength 0.0
>> set pcoords ""
>> set pcoordslist ""
>> set profilelist ""
>> set first 1
>> if { [info exists linex1] } {
>> unset linex1
>> if { [info exists liney1] } {
>> unset liney1
>>     #recalculate elevation range in case region has changed
>> proc GmProfile::cleanup { destroywin mapcan } {
>> # cleanup procedures on closing profile window
>> variable pcan
>> variable transect
>> variable tlength
>> variable tottlength
>> variable pcoords
>> variable first
>> variable linex1
>> variable liney1
>> global mon
>> set tlength 0.0
>> set tottlength 0.0
>> set pcoords ""
>> set pcoordslist ""
>> set profilelist ""
>> set first 1
>> unset linex1
>> unset liney1
>> MapCanvas::restorecursor $mon
